Ticking noise
USMC_Ram909
Just noticed my truck making a ticking noise when i start it up. I haven't noticed this before, is this normal?
CDNUSER
My ticks just slightly during cold start up (below freezing) as soon as it warms up it stops.
If the ticking gets louder or continues it could be a sign of a head gasket or manifold gasket leak from my experience.
U
USMC_Ram909
Well I'm definitely not in that type of weather here in so cal it's only 40-50's cold start.
CDNUSER
Does the ticking get louder or faster as you accelerate? Check the exhaust manifold for leaks.
ckeefer58
Yep, I would say broken manifold studs. Noticed mine most on cold mornings till the truck warmed up. Had them replaced, and she purrs like a kitten even below 0.
Sent from my Nexus 6P using Tapatalk
U
USMC_Ram909
I couldn't notice it when I was driving I did check when I got home right now and no noise, gave it some gas and still nothing.
U
USMC_Ram909
I noticed it on the drivers side btw
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
at cold start up mine had a horrible tick that went away after it got warm. manifold bolt broken on drivers side. probably the issue.
U
USMC_Ram909
So after searching this after you guys mentioned it I found out it's a very common problem. From what I've read it's covered under power train warranty, has anyone done this? I bought my truck used, it's a 2012 with 45k miles
ckeefer58
When my truck first started ticking I only noticed it at start up. As it got worse it was noticable even at speed. But once the truck was warm even revving it you couldn't hear it.
Common issue and dangerous if it is lifter tick no problem if it's exhaust bolts. Take some one inch plastic hose and put one side to your ear, the other to each exhaust bolt. I encourage you do search the forum, it has been covered weekly, many good answers for both main causes of tick. It is called Hemi Tick.
U
USMC_Ram909
Dropping her off at the dealer now. She's still under power train warranty. Find out in a couple of days what the problem is, although I'm positive it's the manifold bolts.3e749adc4888ade94487a28ebba26cec.jpg
RamCares
n/a
n/a
Hi USMC_Ram909,
I'd be happy to follow up with your dealership for you if needed, just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
U
USMC_Ram909
Got the truck back today! All under warranty. Ended up being a warped left manifold and broken studs
Cool!
R.L.K.
Bristol , Tn.
Nice to hear it was covered under warranty!
In the last couple years the #s of broken bolts and warped manifolds seem to be going up at an alarming rate ....
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Question: does the dealer reinstall upgraded bolts to keep this from happening or do they install the exact same bolts so it will keep reoccurring?
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
they told me they only replaced what was broken when I asked, but called back and said they replaced the entire drivers side with upgraded bolts. I guess that leaves the passenger side to fail.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Just makes me curious why the HEII they just don't install the So-Called (Up Graded) studs @ the time of build?
Or are they really Ugraded studs?
Im not a rocket scientist! But to me this is a pretty simple solution!
R.L.K.
Bristol , Tn.
I think the root of the issue is the manifold warping .
Maybe the manifold should be of a different alloy and or thicker to help prevent warpage , and the manifolds should be retained by STUDS not bolts ?
Reactions: SyN
