Tire Size
MTLKEBEK
Montréal
Hi everyone, I'm looking to lift my truck an additional 1" (Currently Leveled at 2.1 with Bilsteins) and fit larger tires (Currently Duractracs 275/60R20) using my stock 20" wheels (No spaces).
Any recommendations on how I can achieve that lift?
Front:
Spacers, or move to 2.8 setting? I will replace the UCA with the Zone adventure series
Rear:
Spacers, or Tuftruck springs?
What tire size would you recommend? I'd like something taller and maybe wider, however, I don't want to use spacers.
Thank you
ilovemyramlaremie
Moravia NY
I have the same set up that you have, Bils set at 2.1
I got 20x10 wheels-19 backspace
285/60/20 tires. Fit and rides perfect. No rubbing issues
BOWERSFJ
Uniontown OH
You can clear 285/60R20 with what ya got now ... With the additional 1” you can clear 295/60R20 ... Yup, Bils to 2.8, and a rear spacer34822cd9851f76b91e45d0cbc31f7226.jpg
MTLKEBEK
MTLKEBEK
Montréal
Thanks guys, but these tires are wider and not taller correct? Do they not make tires like 275/75r20?
BOWERSFJ
Uniontown OH
Go to Tire Rack and search your available sizes ... It will also give you the actual measurments
MTLKEBEK
MTLKEBEK
Montréal
Duractrac's come in 275/65r20 so slightly bigger
BOWERSFJ
Uniontown OH
There are a **** ton of tires that come in that size ... Same width as stock, 1” taller ... I run a Cooper in that size for Winter
MTLKEBEK
MTLKEBEK
Montréal
I've been running Duratracs in Canada (All year round) and I'm very happy with them.
Reticle918
