tires rubbing
generalat2
phoenix az
5.9 magnum
I have a 2001 1500 sport off road edition. i just put 33" tires on it and they are rubbing a little in the front when i turn. if i add 2"-3" coil spacers in the front, will i need to change anything else e.g. pitman arm, sway bar etc???
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
2 inch you shouldn't have to change anything. Isn't that truck an ORE? You should be able to truck 33s with rubbing only in the rear, not the front.
MADDOG
Living in a Firepit
6.4L HEMI
How wide are these 33's?
generalat2
generalat2
phoenix az
5.9 magnum
they don't come anywhere close to rubbing in the rear, definitely rub in the front when i turn, on the front bumper and the wheel well. im not fully sure how stock this truck is, it has 3" blocks on the rear, thought a stock ORE was 2" in the rear, also thinking that i have had some spring compression over the years, it looks to me that it has a slight rake to it.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Interesting. I wonder if someone had been forking with the control arms, because they should be clearing.
I forget how large the stock 4x4 block is, the ORE gets it's lift from an additional leaf in the springs.
generalat2
generalat2
phoenix az
5.9 magnum
definitely a possibility. I think ill try the 2" coil spacers for now till i can get a proper lift.
MADDOG
Living in a Firepit
6.4L HEMI
I agree with that approach. The tires are just a teeny bit to tall, hence the rubbing.
A coil spacer level kit will work just fine.
