Transfer case failure
Goosewhole
Los Lunas, NM
Good morning, y'all. A little background: I'm running a 2017 2500 4x4 CC LWB 6.7L Cummins, 68RFE automatic with 153,000 mi.
A few weeks ago, my truck started making this weird, whining/grinding noise from somewhere under/in front of the cab. I couldn't tell from where exactly, but it was very intermittent and it would just do it randomly. It would only do it while in motion, usually between 40 and 50 mph. I couldn't replicate it. The truck would do it when it wanted to, for maybe a second or two, then quit.
I never felt any loss in power, no jerking, just noise. It gradually started getting worse, so I had a friend look at it. The sound stumped him, but he said it sounded similar to a motor pulley sticking. I had another friend, who is a mechanic at a local dealership (wish I would've thought of him first), and on a drive, he had me shift transmission gears, thinking that might be it, but no, thank God.
What we discovered is that when it did it, it quit when I shift into and immediately out of 4HI. Eventually, it started grumbling in 4HI too, so I'm getting the transfer case replaced. I also found out my t case isn't electronic shift, and there were only three available in the nation, 80+ on backorder. I guess not really looking for advise, but if anyone hears a random noise from under the truck, try that.
gofishn
Iowa
hemi 5.7L, 345 cu in
Thanks for the heads up on availability.
Do you have the specific transfer case Model you can share?
Goosewhole
Goosewhole
Los Lunas, NM
Mine is the BW 44-47. I had to order it in from Colorado, and then UPS lost it, so I'm hoping they either find it quick, or refund my money quick so I can reorder one before I'm completely out of luck.
The BW 44-46 is the electronic version, which I understand is on most of the trucks now, but I couldn't speak for its availability.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
I'm recalling the BW44-47 is the clutch case? Does your 4WD knob have the "auto" function on it? If yes, it's clutches. Possible you burned up a clutch in it. Which is why it needs an oil with friction modifier additives - there's info on this in synthetic oils if you search.
Guys with these have come up with oils that work with these without paying for MOPAR's "secret recipe" transfer case oil. There's nothing "secret" about wet clutches - only the right type and amount of friction modifier additive to allow the correct engagement lockup time span.
I have the BW44-46, which is the old chaincase, with added electronic engagement solenoid - but no wet clutches internal.
Goosewhole
Goosewhole
Los Lunas, NM
I don't have a selector knob. Mine is the old school stick on the floor 4x4 shifter. I just have 4LO, N, 2HI, & 4HI.
What I did forget to mention in my original post is that another thread on a Ford forum that someone mentioned that their mechanic said that can happen from under-use of the 4x4 system, but take that with a grain of salt.
HEMIMANN
Minneapolis, MN
Then you got an old timey chain drive transfer case. Any old ATF will do. I bought 2 more quarts than my transmission took and used those in the transfer case. I would have thought the higher numbered transfer case model would have had the newer "auto" clutches. Just google your model to be sure.
The only difference in the BW new and old chaincases is whether you engage with a stick shifter on the floor or push a button and an electronic solenoid engages. Same guts otherwise.
Goosewhole
Goosewhole
Los Lunas, NM
My mechanic did fluid change and said a lot of stuff came out with it. But he's going to put the new transfer case on this weekend.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Sorry for your troubles. Question, did you ever service that transfer case or was that still the original factory fill?
Goosewhole
Goosewhole
Los Lunas, NM
Likely my own fault. I bought the truck used with 78,000, and I don't know if the dealer that sold it did it a service before they sold it, but I didn't. I was planning on it, but I'm sure I went way over the service miles. My mechanic is going to service the transmission when he switches the transfer cases.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Hey, stuff happens, I was just wondering as that could have contributed to the T cases demise... or I could have just been some kind of internal defect or abuse by the prior owner. Sometimes it's hard to tell.
I service the transmission (drop pan, change filters and refill, not a power flush), transfer case and both diffs every 5 years or 30k miles, whichever comes first.
My truck has 15k miles on it, but I did all of that and drained and flushed the radiator and overflow tank last year just before the 5 yr mark. It was due based on time for me, but I'm more particular than most. Hope they can get you back going soon
Goosewhole
Goosewhole
Los Lunas, NM
I put roughly 25,000 miles per year since I picked her up in November 2019. So I probably should've service all that twice by now. Now I feel really bad. Lol!
I owned a landscaping company, and the truck did exactly what I needed. But I shut it down this past December, so I won't be near as hard on the truck anymore.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Gotcha. Yes the owners manual has much longer service intervals I believe than what I do, but I do all my own work, so it's cheap insurance for me as far as I'm concerned anyway, just the cost of all the fluids. Considering the component cost for those items I want to ensure I do everything I can do get the best service life out of them that I can.
I dont know if you get snow where your located, but plowing is hard on stuff so that could be a factor also. You should also consider installing the block to remove the transmission thermostat that's located in the transmission cooler lines. I did and so did @HEMIMANN. If/when that gets stuck shut or clogged, your transmission will be toast.
I'd research it and think about it anyway. Many threads on here about it. There are several options.
crazy jerry
WY
46 and 47 were the models used on 2500 and 3500. one had a lever. other had electric motor. both had chain. no clutches.
theres no filter inside .just small metal screen. never changing the oil likely is what killed it
HEMIMANN
Minneapolis, MN
Probably from moisture or OEM oil being low quality, either mineral or synthetic. Gear boxes have breathers that allow atmospheric moisture to enter. If left too long, oil emulsifies (looks milky color), loses lubricity and rust protection.
crazy jerry
WY
what are you blabbering about ?
the tcase oil was likely never changed once in 153k. probly looks like black syrup now. thats what killed the tcase. a easy 10min job years ago would of probly prevented all his misery. hard lesson learned but life goes on
HEMIMANN
Minneapolis, MN
Um, "sir", my "blabbering" is from 32 years of professional experience as a degreed mechanical engineer in the oil and power train industry.
How about yours?
Goosewhole
Goosewhole
Los Lunas, NM
UPDATE:
I found a transfer case and got it shipped from Colorado to New Mexico. For a little backstory, my mechanic is a good friend, and he looked at it in his day off in my driveway. Don't go bashing him. He admitted his oversight, and even offered to pay the restocking fee when I ship the transfer case back.
Anyway, my mechanic put the truck on the lift, and discovered the transfer case is fine. Yes, it needed a service, but the noise was caused by the front differential losing fluid.
Once he got the driveshaft off, he noticed the pinion bearings were completely seized, and then noticed the puncture in the front differential cover. Apparently, I had hit something hard enough to put an inch long gash in it, draining the fluid from the pumpkin. He said it should've been a noticeable impact, but I don't remember hitting anything. He did recommend I file a claim with my insurance, since it was a road hazard that caused it. So that's in progress.20230204_102125.jpg
But while the truck is getting repaired, he's going to change all the fluids.
crazy jerry
WY
it wouldnt take much to punch a hole in those stock covers. thats why off roaders use 3/8 or 1/2 nodular iron or high strength steel.
maybe do a under cariage inspection once in a while. just sayin. likely you could of caught it earlier
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Agreed. Good example of why we all need to pay attention to things like this. If you notice your truck is marking its territory so to speak everytime you stop somewhere, you probably need to crawl under it to see what's going on so you can catch things like this early. Or take it to your chosen repair shop and let them check it. The reality is, a lot of folks out there just don't know any better and the percentage that do is shrinking as years pass.
Goosewhole
Goosewhole
Los Lunas, NM
That's the thing. I don't have a single spot on my concrete where I park, so it all, and I mean ALL managed to drain out before I got home. I do watch out for spots, but there was nothing.
