Transfer case removal help needed, stuck to transmission
bornaRAMblinMAN
Top of the world
v8
I can't figure out why the transfer case won't come free from the transmision. I have a trans jack on it, and a seperate one on the trans, all the bolts are out, and I am trying to pry it but it won't give. Is there a trick or something I am not thinking of? Just wiggled it for an hour, its loose but seems stuck on something.. was thinking about using a come along off the axle
chrisp2493
Always Modding
Warren, OH
392 Hemi
Are you positive you got the top bolts out? There were a pain the see and reach when I did mine
I Bleed Ram Trucks
bornaRAMblinMAN
bornaRAMblinMAN
Top of the world
v8
The top nuts were a huge PITA.. finally got it off last night, the posts had corrosion built up inside the tranny case mounting holes so bad it was frozen on.. I managed to free it by kicking the rear end of the case with the jack lowered a hair beneath it so it wasn't being supported, the weight and leverage popped it loose.
Appreciate the reply, thanks chrisp2493
