Transfer case woes
olyelr
Kewadin MI
There are literally millions of trucks driving around with the transfer case hanging off the transmission. A muffler clamp holding it up some more isnt needed.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
thar very well maybe but as i said mine is compromised. so for the price (about 20 bucks cad) i think it will help. i realize that their a bazillion trucks out there that don’t have this problem but mine does. so this is the solution that i came up with. it’s been raining so much lately that i glad that my driveway is on a slope
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
truthfully i think that guy with bigger tires and such should maybe think about some sort of support for how much it costs. i know that there’s some pretty talented guys out there who could probably make something like that only better
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
i haven’t done anything yet alberta beach where i live has seen record rain. but today is supposed to be nice
62Blazer
Midwest
Haven't paid attention to this post in awhile and just catching up. I'm going to say the same as others.
I don't see any reason to "upgrade" the transfer case. You didn't actually break it, rather it was just installed poorly and fell off. That has nothing to do with the strength of the transfer case. If you are concerned with the current one being compromised I would just look for a factory replacement in the junkyard. There is nothing special about the PW transfer case as compared to any other Ram 2500 with a manual shift version.
I wouldn't waste my time with a muffler clamp. Really don't think it would provide enough support to do anything.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
the actual transfer case is fine except for the two compromised studs. i have been driving it the way it is. i m just trying to relieve a little bit of stress on the studs. all the torque and the weight of transfer case hang on those studs. i realize that there is a million trucks that have a billion colletive miles between them but mine is different because of the previous troubles. i think a little bit of insurance is in order. i realize that other people might have a different opinion but that is what i am trying it might not work but it is a simple and simple solution
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
truthfully i can’t believe that this is not more common especially among diesel trucks with more torque.
62Blazer
Midwest
Well, you can do whatever makes you feel more comfortable. Assuming you are talking about putting a muffler clamp around the rear tailhousing of the transfer case. Just be careful because the aluminum casing is not very thick and could see the clamp either crushing the housing, or causing it to leverage up and crack. Honestly I think it has potential to do more harm than good......
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
i’m thinking just to take some of the load off of my compromised studs. i’m going to keep it flexible and i will have to modify the exhaust clamp
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
i have already looked at what needs to be done. im just in the middle of the rear brakes and wheels seals it’s been so apita. drivers side is done tomorrow passenger side.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
as for the tcase fix other than replacing the tcase or at least the half with the mounting face i will if it comes to that. in the meantime im on a fixed budget so im gonna come up with a budget fix. if it works out for the price it would be a cheap and simple upgrade that anyone could do. i’ll keep you posted whether you are a hater or not. just because i am old and dont really care what anyone says or thinks
DILLIGAF
Canadian Forces
Canada
Easy fix, Helicoil the elongated holes and get proper studs. A clamp on the tail wont do anything.
Its all design to flex under load.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
the transfer case is in and this is the fix that i came up with to eliminate any potential future problems the exhaust hanger will allow for some movement and tts just there to take up some of the weight. is it gonna work dunno the only possible problem with this that i can see is if the exhaust hanger comes loose but there is a little bit of forward pressure should be okay i hope
