Transmission heater unit bypass??
Steiblerm
Mcadoo pa
By 2017 V6 ram recently filled transmission with water and I suspect it was from the unit on the side of the transmission that flows coolant to it. Is there a way to by pass or delete this all together so it doesn't happen again?
If the transmission had water in it, most likely from being submerged in/under water. Check the breather tube that comes off the top of the trans if the tube is still in place and not broken.
If ithe transmission TMU was the culprit you would have coolant in the transmission, it should have been distinguishable from water. The TMU would have been replaced.
Usually the only reported problem with the TMU is the thermal bypass acts up and the trans runs hot.
You would need to bypass the coolant piping from the TMU
S
Steiblerm
Mcadoo pa
It wasnt underwater because it was in my garage after an engine replacement. Do you think the TMU would get water in the trans? Its being fed from somewhere because it was milky and it keeps coming out pink after flushing it again and again
caulk04
Supporting Vendor
It would be worth pressure testing the coolant system and finding the leak. You could also just remove the heat exchanger from the TMU and pressure test that. I suppose you could also just remove and loop the coolant lines, if it's leaking you should end up pushing trans fluid out of the heat exchanger.
To do what you're asking, remove the heat exchanger, loop the coolant lines, drill/tap/plug the ports from the TMU-heat exchanger, remove the thermostat in the TMU.
A little work yes, but not expensive really.
S
Steiblerm
Mcadoo pa
How do you think it's possible that coolant/water got in the transmission in such high quantity?
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Yes a bad cooler can cross contaminate the ATF.
Remove the cooler fill the ATF side with fluid. Pressure test the coolant side. There should be NO bubbles coming up out of the ATF ports. If there is, that's the issue.
I've seen external coolers and internal (inside of radiator) coolers fail.
How many threads do you think you need on this subject
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Start reading here,there's pics of the TMU,and there's even a pic of how i originally looped the coolant hoses together,before i broke down and replaced the heater hoses with the factory 5/6 speed heater hoses.
Jtucker21990
