Transmission pan
chrisdaleysr
Connecticut
I have a 2021 ram 2500. Has anyone here brake there transmission pan? Dealer said I must of hit something. I told them no way. I said the transmission blew up. Truck has not been off road.
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
Never being off road doe not mean something on the road did not bounce and hit the trans oil pan !
Btw I am NOT repeat NOT standing up for the shop by no means just throwing another explanation out there !!!!
SniperDroid
Eaton Township, Ohio
Had a 1990 Olds Cutlas Calais, daughter drove over high railroad crossing... cracked the cast aluminum oil pan. She never knew it happened.
Dinky
Oregon
I would ask for the pan. Look for yourself if there was any kinda impact there will be marks not just a crack. Also look inside the pan they are a cast part look for imperfections on the casting.
Gondul
Central Florida
2019+ transmission pans on the ZF8 are plastic, not cast.
Dinky
Oregon
Ok so injected plastic that could have a bad injection with air pockets even worse. It will also still have a impact mark ad well....
Dusty
Rochester, New York
Are you the only one that has ever driven your vehicle without you in it?
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 83202 miles
farout75
Laurie, MO
2019 Limited
5.7 L
Try using a spell check, some pretty simple words misspelled. brake = broke, there = their. The spell check is free to down load, makes you look like a college grad.
C
chrisdaleysr
Connecticut
Regards,
Dusty
Yes I am the only 1 that drives
BigMike518
Yes I have damaged my OEM PLASTIC pan. Elk hunting I backed up over a juniper stump hidden in tall grass. Lost all fluid within a minute, had to pull the neutral strap and get towed out of a nasty 4wd trail back to camp, go into nearest town (different truck) and picked up the last pan Napa had in stock plus fluid. Had to make 2nd trip the next morning to get a hand pump to fill it and a torx wrench set to get that damn bolt above the exhaust off. let’s just say skid plates were ordered right when I got home after the TT blew a tire on the way. FUN TRIP
chopperdog45
GA
CTD 6.7
This just happened to me in my wife's Explorer last night. We were driving on the interstate and a 6-inch piece of 2x4 got kicked up by the vehicle in front of us, causing it to cartwheel under the Explorer. It hit the trans pan and cracked it.
