Mike Daley
on my 2012 5.7 i have an annoying belt squeal. When it's cold it's all the time, when it warms up it's only over like 800rpms roughly. Sprayed the belt very lightly with wd-40 and it stopped instantly. So I figured it was the belt. Removed the belt and it seems in perfect shape. Not dry and cracked or tearing. Upon further investigation I found a bad idler (replaced this about 6months ago) and a bad tensioner pulley. Replaces those and the belt still squaled. Removed the belt again and noticed that the power steering pump shaft will walk out maybe about a 1/4" or so if I had to guess. There is no play up or down, only in and out. Is this normal or is this the cause of the noise?
