Tuner Question For 2016 5.7 Hemi
cubmedic
Danville, Va
Hemi 5.7 e-torque
So If I install the ECM and tuner on my Ram and have to take it to the dealership for anything, will they be able to flash the ECM and disable the tune?
Tach_tech
5.7L HEMI
If you have a tune installed and take it to the dealer and they do a PCM flash it will put it back to stock.
cubmedic
cubmedic
Danville, Va
Hemi 5.7 e-torque
Will I be able to reinstall the tune?
MADDOG
Living in a Firepit
6.4L HEMI
I'd return the unit to stock before going to the dealer so that the tune or the PCM won't get scrambled.
MADDOG
Living in a Firepit
6.4L HEMI
echo... LOL
whetrick1
But doesn't it lock the PCM if the dealer flashes the PCM. That's why I bought a Diablo PCM so I could switch them out.
Tach_tech
5.7L HEMI
No it doesn’t.
whetrick1
I thought that 2015 and up they locked the PCM
Tach_tech
5.7L HEMI
The PCMs are locked from the factory in that you need a PCM that has been unlocked by someone like HP or Diablo. Flashing the PCM does not lock it.
whetrick1
OK. I thought the way they told me that anytime the dealership flashes the PCM that it locks it. I must have misunderstood.
boomstick
mississippi
all ive ever heard that if the dealer flashes it it relocks it. if you buy a seperate pcm then just put the stock one back in and then take it to the dealer
Sent from my SM-N950U1 using Tapatalk
whetrick1
That's what I did I bought one from Diablo and when I take it back to the dealership I swap them out.
boomstick
mississippi
its more expensive but alot easier.
whetrick1
Yeah it is all the way around lol
Ramitiner
U.S. ARMY VETERAN
NJ
Thought the "lock" was a hardware thing that needed to be physically removed vs a software lock
whetrick1
No its a software lock
Ramitiner
U.S. ARMY VETERAN
NJ
How can that be if it can't be unlocked via software? That's why we have to give a pcm
whetrick1
It can if you have the right stuff. Diablo can unlock them but they will charge you to do it. That's why I change out my pcm before I take it to the dealership.
