Uconnect GPS issues:
Rleeunc
Raleigh, NC
We went out of town a couple of weeks ago. Upon our return our GPS/ Nav is stuck in middle Tennessee and the clock is in CST. I have tried a soft reboot and factory reset, but no help. Any suggestions as what I can try next? Thanks !
RamCares
n/a
n/a
We would like to take a look into this to see if any Uconnect updates are available. DM us with your VIN in order for us to get started.
Chris,
Ram Cares
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Is this a factory installed RA3 or Ra4 8.4 radio?
(Ie 2014 RA4).
What SW version is the radio on? (18.45.x is latest)
... And reported radio Part # from settings menu?
Rleeunc
Rleeunc
Raleigh, NC
Software version: 18.45.01
HU Part #. 68224525AM
Radio replaced by dealer 2 years ago as it was DOA. Looks to be the same as the old one.
RAM 1500 Big Horn 2014
Thanks!
Mpgrimm2
SC
5.7L
It's less likely but possible, a failing roof antenna could be part of the issue.
If you don't use/need Chrysler 's uConnect phone services app to lock/unlock the truck etc via the radio (OBD port dongle now), you can find a used 3c Harmon 8.4 RA4 radio on eBay for, $150-$300 (last 2 letters, AA, AK, AM, etc don't matter, search 68224525 ) ... a 2017 RA4 (68270661 would also be a direct swap w/o any programming changes or extras.
Or if you have a dual zone ATC (Auto Temp Climate) HVAC truck and aren't running a custom engine tune, it's not a far jump to get a compatible 2018/19-21 4th Gen Ram Panasonic UAq or UAs 4c in there with Android Auto/Carplay support see here and here (no dealer support though). Also need a different USB hub in the console at a minimum.
jimn
