UConnect Software Update Received--What's in it?
MJockey
TENNESSE
Hemi 6.4L
http://www.mediafire.com/file/38demsl2m94i4xy/UCONNECT_8.4_UAQ_IR22.6_MY18.zip/file
Here it is. Download it to your hard drive then unzip it to a blank USB drive and follow the instructions in the TSB.
Note: when I got to step 14, I turned the key from Ign to Acc instead of off like it says in the TSB. It worked and I could see the process. It took about 20 minutes like it said. I did put a trickle charger on it just to be safe. If you don't want to sit in your truck the full 20 minutes, exit during the two minute count down in step 14.
Hope it works for you all. It's has been a long wait.
g00fy
Cummins 6.7
thank you so much!!! Downloading now!
chri5k
USA
Diesel
I pinged Mpgrimm2 on this so he can add it to the firmware thread he created in 4th Gen DIY forum.
g00fy
Cummins 6.7
Worked for me, I was able to turn my bass back up to +2 from the -6 it was on. It sounds so much better now I'll report back about the voice volume levels after my drive to work tomorrow. Thanks again mjockey!
chri5k
USA
Diesel
This is great news! Mjockey, buy that tech who gave you the file a pitcher of beer. Heck make it two since you're buying. :D
MJockey
TENNESSE
Hemi 6.4L
Ha, ya I lucked out the right tech walked by while the service advisor was saying I don’t think we can do that. He show the tech the TSB ( I had the whole file this time) and the tech said it customer preference. 20 minutes later I had the file.
MJockey
TENNESSE
Hemi 6.4L
Your welcome, glad it worked.
I wonder if it will work on my sister in-laws 2019 Mini van?
Tankerpilot01
Lawson, MO
Cummins
Will they ever push that update OTA? Or will it only be via a manual update via USB?
appzattak
Jerome, Idaho
Gracias! Updated mine, took about 20 mins.
Sent from my Pixel XL using Tapatalk
18harvest
huntsville
well hell found the problem.after all this time my current uaq is from the great white north.and it has a manufacture date of march 19.probably a 2019 radio.doh
chri5k
USA
Diesel
I sure hope not. OTA updates are wreaking havoc on our RA4 brethren. Failed updates, bricked radios, dealers unable to get new radios, etc. It is a total Charlie Foxtrot. The TSB gives a clue why FCA wants to do OTA updates, so they don't have to pay the dealers 0.2 hrs to create the drive and 0.5 hrs to check the version / update software per vehicle.
MJockey
TENNESSE
Hemi 6.4L
Yea, the file has "MY18" in the name, figured it would only work on 2018 radios.
g00fy
Cummins 6.7
After the **** at the dealership wouldn't help me, i called Uconnect to see if they would help me. Of course the idea of putting a UAQ in a 2015 truck was pure blasphemy to them as well, so they wouldn't help me either, but the guy did mention everyone was supposed to get this updated OTA by November 4th.
Honestly i'm glad i got it Via a direct USB update then trust the OTA network.
On another note, the system voice volume is much more tolerable, it still defaults to volume level 15, but it's much more reasonable and not booming at me, however now it sounds like the voice is coming over AM radio lol, which i don't care i can still understand what it's saying it's just not as clear. I still turned the volume down to 5, so i'll see when i go on lunch if it resets to 15 or stays at 5.
18harvest
huntsville
I was able to update a uas from a 2019 ram classic with a 18 file but the radio manufacturer date was dec 18.so do not know if it's because it's from Canada or the manufacturer date or a combo.
chrisbh17
Im sure this is not surprising at all, but the only radios that need that update are RA3/RA4 (VP3/VP4).
The UAx series are not affected by the same "GPS bug" AFAIK.
So basically UConnect had no idea what they were talking about....as always.
