Yesterday I had the dump trailer loaded and backed down the driveway. When I tried to go forward, the truck would not move. It acted like the torque converter was holding in stall speed with the parking brake on. The driveway is dirt but the tires were not spinning. I turned off the traction control but the same result. I put it in 4 WD low and it went up the hill slipping the front and rear tires a little on the way up.
This is a 2017, 2500 Laramie with the Cummins. 68RFE trans (I think that is the right amount of numbers and letters). It has just over 5,000 miles.
I thought these were torque monsters and I would have expected the rear tires to be breaking loose with the traction control off.
The trailer was about 14,000 pounds and the driveway is probably 7% grade. Admittedly it is a heavy trailer on a pretty good grade, but I was expecting tires to spin at some point.
Today, with the truck empty, no trailer, I floored it on the dirt road. No tire spin with the traction control on or off. After about 50 ft the power came on and the tires began to break loose.
So, is this the normal way for these trucks?
