You are going to have a few issues with installing a used PCM. It's just not a simple swap like it used to be. If you install a used PCM it will have a different SKIM OIN programmed in it. Your truck won't start. It will start and die because the PIN does not match the truck.I need to get a used ECM for my truck. 2006 ram 1500 4.7 v8
How do I determine If I find a correct match
I meant to ask you earlier, why does your truck need a PCM? What type of problems are you experiencing?I need to get a used ECM for my truck. 2006 ram 1500 4.7 v8
