Warlock LED Headlamps
Mb7640
Fountian hills az
In my 2021 warlock i have auxbeam led no issues and it makes a huge difference
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
How did the installation go?
Also, how long have you had them on your truck for?
Thanks again!
Mb7640
Fountian hills az
Thanks again!
It was not bad have to remove the headlight assembly. I watched a u tube video the instructions in manual are not that clear. I installed them first of January so far so good. I was just going to do low beams. Since have to remove the entire assembly I figured better do both
PaleFlyer
Charlotte NC
I did High and Low in my '18 Rebel (should be the same for a lot of things to your Warlock), I don't love the brand I used, but even the crappier bulbs I used vs the Lasfit linked, made a HUGE improvement. All 4 bulbs are the same 9005 if you have the projectors (which I think you should). There is supposed to be a way to do it without removing the grill, which was a pain in the ass.
EagleChief
Oklahoma
2014 Big Horn
Not sure what housing the Warlock has, but I have a 2014 with the quad halogen headlights and used the Fahren LED bulbs. They work great and have a pretty good cutoff line to keep from blinding other cars. I have yet to be flashed with the new bulbs in. Ended up using them in my lows, highs, and fogs.
RamHemi18
I'll second the Fahren bulbs. Great light output. I had to adjust my lamps because they were off a bit. But I like them a lot
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
Thanks for the info everyone!
I just picked up the truck today and so far the OEM lights are doing the job :)
One less thing to get for now
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
I'm looking at these now, which one did you end up going with?
- Auxbeam 9005 HB3 Led Headlight Bulbs with Turbo Fan, 60W 12000LM 6000K White 9005 LED Conversion Kits Replacement Fog Lights Headlights Halogen Bulbs F-16 Series
- Auxbeam 9005 LED Headlight Bulbs F-16 Plus Series LED Headlights with 2 Pcs of 9005 Led Headlight Conversion Kits 70W 14000lm High Brightness SMD LED Chips Driving Light
- Auxbeam 9005 LED Headlight Bulbs, NF-Q9 Series 9005/HB3 6500K Cool White Super Bright Light Bulb with Wireless & Noiseless 40W 10000lm Lumen 1:1 Light Bulbs 200% Brightness Replace for Halogen Bulb
I'd like to change them before the winter. Thanks!
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
It's got projectors
Mb7640
Fountian hills az
I went with the q20 for low beam and the gx for high beam. I installed the fog lights myself with factory led. Mine did not come with fig lights. I also have projectors
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
So it's none of those haha!
If you got a link for it, that would be appreciated!
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
Both links work, thanks!
This doesn't impact the auto feature on the lights, right?
Did you order the decoders as well? or just the bulbs?
Thanks again!
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
For any one that's interested in these:
LASFIT 9005 Bulbs 60W 6000 Lumens Super Bright for Car, 2022 Upgrade HB3 Bulbs Automotive, 6000K Cool White 360 Adjustable, IP67, Plug and Play (2 Bulbs)​
They DO NOT fit in the high beam slot (hits the housing and can't go into the slot at all and the low beam hits against the housing cover... waste of time with these ones.
It's now obvious, that the reviews that said it worked, they either cut the back housing cover or screwed it in with the fan pressed again the housing cover.
hunterdan
SE PA
2019 classic
Hid are a huge upgrade in the factory projector.
I'd go with hid low and find a decent led high beam that fits.
If you don't want to cut the dust covers, you can buy extended ones that give you more room.
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
Thanks for the info!
I won't pay $70 USD for dust covers though, that's ridiculous.
I found a slim set of LEDs (from Lasfit), if it doesn't work, I'll just add a light bar and call it a day.
StateOfMind
Orange County CA
The 2024 Lasfit LCair bulbs are the same length in front of the connection (bulb side) and behind the connection. No need for dust covers or cutting. Also the decoder is built on to chip. Only issue is they are not clockable, although they state they are preclocked.
