Well that was unexpected ! Lifter gone 52,000 miles.
One of the quickest cars in my old high school was a little 70 Dart Swingerr with a healthy 340/4 speed and a set of 5.13's in the rear. It was only good to 110 mph,but it'd get there in about a block,lol. The prettiest car was a 72 340/4 speed B5 Blue Cuda though
Ludville1
5.7 Hemi Sport Crew
Amen Brother! Back then a girl that I worked with had a 1969 Dart Swingerr with a 340/4 speed, headers and gears (not sure what ratio). I got to take the car for a ride...good God what a quick little car!
pacofortacos
71 383 4 speed Cuda - still sitting in the garage just going to waste :(
I need to build a garage and restore it or finally sell it, I have had it since 79.
Has a junkyard 440 in it now, 400 in front of it and another 440 behind it lol.
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
ours was a nova (graduated 87) i don't remember what it had. i had a 76' camaro 350, 78 280z, 82 280zx, and a 85 corvette
Ludville1
5.7 Hemi Sport Crew
Cool car! Guy in the old neighbohood had a '71 Challenger 383/4 speed pistol grip...great running car!
M
Motorhead440
Currently overseas and my wife sends me a video of her 2016 Ram 5.7 with only 52,000 miles on it and it's making a racket. She said she was driving home and suddenly heard a loud tick sound and the truck lost a little power. She drove it the additional 5 miles to the house and parked it. Never had a lifter tick before. Mobil one 5-30 and the same Mopar factory filters and Mobil 1 filters I use on my Scat Pack Challenger. I have changed the oil and filter regularly in the truck 12 times. I'm obsessive and keep great records. I even changed it once because I was bored! No mods. It's my wife's truck and she drives like a normal human being. I can only figure defective part . its about 3 months out of warranty. I guess I'll tear into it when I get home in 30 days. I know it's a tired subject but I think mine is a little different in that it was driven only 52,000 miles. I'd enjoy hear everyone's thoughts on a 52,000 mile truck that wiped a lifter. Have you seen a low mileage truck wipe one out like this before?
https://youtu.be/B80dpi4wSlY
So I'm back listened to it close and concluded it to be tapping on the Drivers side cylinder #1. Today I finally got time to tear into it. Removed the left valve cover and immediately observed excessive lash on #1 intake rocker as compared to all the others having essentially zero lash. Pulled the head and lifters and this is what we have. Cylinder #1 Intake lifter seems to have experienced an internal failure. As the truck was not run for more than 10-15 minutes after the tapping began, there was no damage to the cam whatsoever. Everything looks great. I am going to be replacing the failed lifter and continuing on.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Great quick catch......low pressure/lack of oil or bad needle bearings theories go out the window on this find.
Wouldn't take long to eat away at roller & cam with a collapsed lifter.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
How does this explain heavily additized lubricants and low restriction oil filters eliminating lifter ticking in 80% of cases. Are you suggesting there are multiple failure modes in Hemi valve train design?
crackerjack1957
Looks to me like he proved his case as a internal lifter failure.....not the lifter roller/cam.
Picture worth a 1000 words.....LoL
Think about it this way.......lifter/lifters collapse.....they keep driving with ticking noise.....destroys roller & or cam so oil/pressure has nothing to do with it.
They see roller is damaged & thinking maybe it caused the internal lifter failure.
This is assuming of course dirty oil not restricting lifter orifice.
M
Motorhead440
^^^Nice that you caught it early before it ate up the cam.
Are you just replacing the one failed lifter then?
I reconsidered my original plan to replace just the one and decided to replace all eight on the left side with Mopar lifters 5038785AD. Replacing the pushrods with Competition Cams 7914-16's. I'm replacing the exhaust manifold bolts on that side as well as replacing the plugs all around. Interesting to note my manifold bolts were like new and my factory plugs were NGK Iridium's; I was expecting Mopar.
M
Motorhead440
Hmmmm The Comp Cams 7914's are significantly shorter than stock. I'll stay with my straight stock ones. I have also provided some endoscope photos of the cam lobes to reflect no discernable damage or odd appearance difference between #1 Intake and exhaust #3 , #5 and #7
M
Motorhead440
Got it all back together. New oem NGK Iridium spark plugs all round. Fired right up. After everything settled down, no tick. However, I can tell #1 is still missing and it still throws P0301.
Swapped coil packs , still P0301
Swapped Fuel injectors , still P0301
What's the possibility that the MDS solenoid for #1 is bad and failed in such a way to only throw a P0301? I knew I should have replaced it while I had the intake off and I forgot. It's probably what made the lifter go bad.
Dieselhorses
Baton Rouge, LA
345 cid
Something in the primary wiring or yes, it could be MDS solenoid. I'm sure you reset code...? The ecm may still be compensating for the failed lifter but I'm not a tech so...
DILLIGAF
Canadian Forces
Canada
These engines are easy . Take all the MDS crap and throw in the the trash. No more codes once rebuilt and tuned.
