MCas86
Georgia
Looks great.... but it never "ends". Never :waytogo:
Yea... hence the "ish". I want new black step bars, vararam intake so I can add another battery, a new hood, drilled and slotted rotors, etc.
What I really want is a cab visor but I can't find one I like, its like the windshield is too slanted to get a decent look that I want.
2012RAM1500RT
nowhere
Added the air bags that go inside the rear coil springs on my 1500. Will probably add about 3 inch raise if needed. Put a camper shell on and will have a few hundred pounds of camping gear for camping next month. I hate the "broke back mountain" look and just wanted to keep it level!
tones2SS
MA
Cleaned the interior up a bit.
Washed the WeatherTech floorliners which were pretty bad. Not so much the passenger's side, but the driver's side was pretty bad.
Nerveex
Syracuse NY
ive been looking at replacing my coils as they sag a little, should i just go with factory is there a better aftermarket option? i dont really need heavy duty ones as i dont use the bed all that much
2012RAM1500RT
nowhere
Might want to think about air bags, you can raise it if needed if you use your bed. Under $100 also. They are not meant to make your truck haul more than it's supposed to, just keep it level when you haul the max.
stembridge
The Middle South
Pentastar 3.6
Installed and set up a CPLAY2air dongle, so I now have wireless CarPlay. It freaked me out at first, as after installing and updating to the latest firmware, the display was very 'smeary' and low-resolution. Upon restarting the truck, it was displaying properly, and has worked well since.
Now I need to find a way to mount a MagSafe charger where the phone will be handy, but not in the way nor likely to be shaken loose.
es
Average_gatsby45
Cummins diesel.
did you have any problems popping those bolts out?
i couldnt even get the first one to 2 with 2 different ratchets and an impact
