Whistle
Beerman64
Colorado
Hello, new here but not to Ram. This is my 5th Ram but first 2500. 2024 6.4 8 speed. Question is when cold upon start up I get a whistle or “squeal” that goes away when warmed up. Kinda sounds like around the tranny area. Any thoughts? Thanks in advance. Brian
Burla
Army
2010 Hemi Reg Cab 4x4
A known issue with rfe's, not as much with 8 speed, but flex plates would have to be main suspect. The rfe's have a peep hole, 8 speed might too?
Whistle is rotational, so check all items that rotate such as belts. Long shot starter starting fail.
Burla
Army
Should check trans fluid which is no small task, but low tranny fluid could cause torque converter to whistle. Get down there on a cold start with stetho scope and find it. If it isn't a belt frey, you will want to identify this item sooner then later.
