winch fail
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
well, i finally got around to tensioning my winch cable on the P/W.pulled it all out,hooked a sn@tch block to the tree out front at the end of my driveway,slight icline.ran it through the block and back to the front towhook.started pulling in neutral,got about 10 feet in and it failed.i can wind it in and grab the rope and pull it out as it's retrieving.it goes in to the dealer on Aug.11.i'll get my first oil change and tire rotation while they got it.my oil changes are covered by my warranty.anyone else have a Warn winch fail right out of the gate?
jabartram
Corpus Christi, Texas
2020 Power Wagon
did you check your free spool handle on the left side of the winch to be sure its fully engaged?
SeppW
Northern VA
Hemi 6.4L
Was truck idling? Thermal protection or low voltage interrupt could have activated, for some reason. Ground to motor. One of contractors failed or shorted (nder the black cover, sort of resemble old Ford style starter solenoids). Tap the motor with a hammer, could have sized up from something inside the motor case. I talked to Warn sometime ago about upgrading the solenoids to solid state or better mechanical type. The guy I talked advised the best course of action is spool out manually(free spool) and winch in once a month. Keeps everything lubricated and exercised.
bcbouy
bcbouy
2021 power wagon
hemi
my trucks and sidebyside always run while winching and the truck has dual alternators.i have no interest in running down the problem,it's under warranty.i'm just wondering if this has happened to anyone else.i wonder if the freespool lever let go and broke internally.it doesn't make a grinding,clunking, scraping sound when i spin the drum.i've never had a winch let go on me before and had to break it down so i have no idea what it could be.fortunate that it happened now rather than when i need it,and i will need it.
Keith67
Albuquerque
That’s lousy. I’ve used mine many times in the mountains and it’s always worked well. Definitely smart to test it often and especially before you really need it. Please update this post after the dealer fixes it, I’m curious.
BigLazer4u
North Carolina
Cummins
Yes, mine went out and did the same thing as you describe. The winch had a mind of its own. Dealer replaced it. 2019 power wagon. I recently sold the truck, I loved it but the truck did have a lot of issues.
bcbouy
bcbouy
2021 power wagon
hemi
due to my location,it's highly unlikely the dealer will repair the winch.more than likely they will order me a new one.
4xdad
Edmonton Alberta
2015 powerwagon
mine failed the only 2 times I tried to use it corroded wires and bus bars none of that is sealed that well. the winch is a pain to remove and install get strong help
DILLIGAF
Canadian Forces
Canada
Were are the control boxes mounted on the PW ?
DILLIGAF
Canadian Forces
Canada
This is where it is mounted on my 16.
Make sense why they stop working. Easy enough to relocate under the hood.
My control box is up high by my air filter. Cost me 40$ in wiring to put it up there but well worth it to keep it out of the weather.
crazy jerry
WY
what did you expect. its made in china crap like most everything warn puts their name on.
as for getting it out and in the truck. ya its a bit heavy but not complicated. i did it myself. floor jack helps
bcbouy
bcbouy
2021 power wagon
hemi
i finally got around to getting my p/w winch replaced.it completely seized at the worst possible time.i also had an oil temp/pressure sensor and a the thermostat/temp sensor replaced.just over 11k kilometers on it.
