Wouldn't shift into reverse, code P1D92
turboguard
South Carolina
2019 Classic Warlock
So I fired up my RAM and went to back out as usual, except when I stepped on the gas it acted like it was in neutral! I looked down and noticed the light above reverse was blinking. I could go back into park and go into drive, but reverse wouldn't engage. After a couple more attempts it finally flashed the CEL. I turned off the engine for a few minutes and turned it back on and it finally went I to reverse. CEL was still on, pulled the code and got a P1D92. It drove and shifted just fine. Obviously have to wait until Monday to take it in...but any ideas in the mean time??
Tach_tech
5.7L HEMI
P1D92-00-INCORRECT GEAR RATIO - CLUTCH 4 DEFECTIVE
That dtc basically means there’s an internal transmission failure. Valve body would be the first thing to try. If a new valve body doesn’t fix it then the transmission is going to have to come out.
personally I would clear it and see if it comes back.
indept
South Jersey
All due respect Tach_tech I would recommend taking it in with the code and documenting this. Clearing it may kick this issue down the road and wind up costing turboguard a lot fixing a latent issue after all warranties expire. It's not normal to get these codes. If it's a valve body or just a loose connector somewhere the OP should get it fixed on FCAs dime.
turkeybird56
Central Texas
^^^^^^^^^^^^^^^^ Exactly what INDEPT said. Because if U not get it Documented by FCA, good luck..................just IMHO.........
Tach_tech
5.7L HEMI
I would only recommend clearing it and waiting to see if it comes back if he has no warranty. I should have made that more clear.
That being said if it’s only happened once and isn’t active when/if he takes it in. They’ll likely clear the code, road test it and see if it comes back. If it’s an intermittent issue it’s more likely a valve body issue.
turboguard
turboguard
South Carolina
So the code cleared itself today, but I'm still gonna take it in tomorrow for its first oil change + tire rotation, and I'll mention the issue.
RamCares
n/a
n/a
Hi @turboguard - If you are in need of any additional support while addressing this with your dealer, please do not hesitate to follow up with us via PM!
Mark
RamCares
turboguard
turboguard
South Carolina
Welp I decided just to let it go for the time being since the CEL went away and I would've had to drop it off overnight. Big mistake, it happened again today when I went to back out for lunch, and never fixed itself, even after disconnecting the battery. Currently having it towed to the dealership...hopefully it won't take long to fix, I really think it's something electronic and not with the actual transmission.
I was trying to be positive, but chalk me up as another FCA statistic I guess...
RamCares
n/a
n/a
I regret to hear this update, @turboguard. Please be sure to keep us posted on your dealer's findings. If if would be of interest, I am more than happy to escalate a case on your behalf for further support as you work with your dealer.
Mark
RamCares
turboguard
turboguard
South Carolina
Mark
RamCares
Thanks for the reply. I called the dealer and they said it was the valve body, but unfortunately the part was on backorder for 2 weeks...anyone else had a problem like this with only 5k miles on the transmission?
RamCares
n/a
n/a
Sorry for the delay, @turboguard. I can get you connected with a specialist who can work alongside your dealer to try and get this in sooner. Feel free to shoot me a PM if it would be of interest.
Mark
RamCares
