Wow
Brandon-w
Yukon
2015 Ram 1500
How much better than factory do you think they are?
Hemi832
Hemi832
Houston
Those were the duralast gold from autozone.
JB1
Houston, Texas
I need to do this upgrade too, how many miles where on those old pads?
4eyedconekiller
North MS
EcoDiesel
I’m about due some fronts... I’ve been eyeing that setup a while.
Is it bad that I kinda wish they had a bigger rotor? Something that would fill up the wheel barrel?
Hemi832
Hemi832
Houston
I was looking for a bigger rotor also, but that was going to take alot more money and the wife said nope.:patriot:
4eyedconekiller
North MS
EcoDiesel
Baby steps, bro. Baby steps! Who makes the kit with bigger rotors?
This is also coming from a guy with 17” wheels, but my mustang fits a 13” rotor comfortably in a 17x9
Tumbleweed
I don't know about our trucks, but Dynatrac makes a (BBK) Big Brake Kit for Jeep JK Wranglers that includes bigger rotors & caliper relocation brackets that move the OEM calipers further out for increased leverage. Pricey, but needed for larger, heavier tires & wheels.
Hemi832
Hemi832
Houston
Didn't get a pic, already took them back to autozone. The bottom right shows little bit.
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
well that is the answer to my Question .Those brake pads are the worst on the planet from Auto Zone stopped using them well over 12 years ago on my vehicles,which I do all the brake jobs on. Bendix,or Mopar that is all I use. when you use Auto Zone brake pads it sounds like a city bus stopping with all the squealing noises they make
KeepRight
ExFalconFxr
US
EcoDiesel
So, misconception on brakes. Eliminating the 'wear' indicator squeals...
Semi-metallic pads will make noise. It just depends on usage. Some of that noise is from poorly greased brake pads hardware. The thin metal that holds the pads, clamped to the caliper mount. These will squeal horribly at times. Need to apply more grease, good quality syn grease.
If you have loud noises and it feels like you're fighting to stop - time to tear things down.
You shouldn't judge quality and wear by just looking at the pads. Need to see true wear, thickness vs milage, rotor wear, etc. Looking at the pads straight on, it's hard to say.
There isn't anything wrong with OEM parts brake pads etc. There is better aftermarket parts.
BTW you'll replace front pads twice as much as rear..
Lurchav8r
