Smoothed CAM?
Backwoods
So i had a ticking noise coming form my motor last week. It sounded like a lifter ticking, I took it to the dealer since its still under the power train warranty. They have had it since Friday so I called today to check on it. The guy said it had a smoothed cam and in fact it was the lifter ticking. Has anyone else heard of this, should I worry about other things failing because of this? I have a 2011 1500, 5.7 with only 50,000 miles and no aftermarket items. I change the oil about every 6k miles with full synthetic.
Burla
2010 Hemi Reg Cab 4x4
Lol yup, just posted about this earlier and you are not alone. Just another reason to address Hemi tick before your Cam smooths out. How many miles did you have that tick? Shouldn't have any issues after they replace the cam and the bad lifter. Ask them to give you the condition of your other lifters if they can, and get the old Cam if you can. Look for any signs of wear other then the bad lobe. Ask them what it woulda cost out of warranty.
Backwoods
Backwoods
Thanks, I'll call them back tomorrow and ask them to save the part. I noticed the tick last weekend, I changed the oil the week before and did't notice the noise when I pulled in the garage. So it had to start within a week, I think My exact milage is just a little over 49,000.
SyN
6.7L CTD Owner
Tornado Alley
2017 4WD - Tow Prep Pkg - Off-Road Pkg - 3:42s w/Anti-Slip
6.7L CTD
Backwoods: That is horrid news! Please keep us up to date with the findings! Hopefully things will be back to normal in a short time...
Backwoods
Backwoods
I know, it's really disappointing. I'm just glad its covered by warranty, they said the motor is in 1,000 pieces right now.
Burla
What oil did you use when you changed it? What filter? That was the same thing the other guy said, it was only a week of ticking before the failure.
Backwoods
Backwoods
I think i used Vavoline synthetic with a fram filter.
Burla
So here is your oil analyzed before running in an engine. No molybdenum which is the element that helps metal to metal wear before the oil gets there. Read mole basics. Just saying you might want to choose an oil like penzoil synthetics that have Moly. Your lifters are dry at startup, you can't hold all of oil up top. Almost every oil has Moly, the two main ones that don't is Valvoline and Royal Purple, but other like walmart oil omit it as well. here is a list, pick an oil with good Moly.
I really encourage you to spend the money on Royal Purple filters. I cut one open today (syn thread) and 14 months of use still looked new.
JasonK94Z
Anderson, SC
I like to use Liqui Moly mos2 also. It's good stuff along with my Pennzoil Platinum oil.
Backwoods
Backwoods
Thank you, I didn't know all that I thought synthetic oil was synthetic oil. After this I will definitely be buying a high quality oil and filter. This is my first gas truck, I always owned diesel trucks.
Burla
YW, read the syn thread.
Well, just like the gov't took the good stuff out of diesel, they have also forced ethanol on all, lowered zinc in oil, force low weight oil on us, force gas mileage measures such as vvt, MDS, etc etc. Yeah, I would say finding a good oil is a good plan. I am not saying if you had Moly this wouldn't have happened, but it is certainly "possible" this wouldn't have happened. When I went to a high Moly oil, my tick ended.
So when the cam hits the lifter but the lifter doesn't lift because it is sticky that can also cause that roller to fail. So the last guy had a crushed roller, how does that happen? Either the roller isn't rolling or the lifter isn't lifting, my money is on the lifter. I think an oil that cleans well and has good moly is what we need. In my unprofessional opinion, I think that is a widespread problem, the lifters not lifting like they should. Oil is just part of it, Ram needs to fix this chit IMO. If I was an engineer there, hemi tick would be a memory. I wouldn't sleep until I fixed it. Nobody gives a chit anymore is my sad experience.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
I had off work today! Spent the whole morning doing spring yard work! Rest half of the day I have spent searching over Many Challenger/Charger/Ram forums all over the net reading about thousands of so call Hemi-Tick issues! With many owners blaming Lifters! Good Lord-->You would not believe all the crazy items being blamed for this issue!
This is from 2012-13-->I have counted over 22 New hemi owners taking their autos back to the dealers for a diagnosis of the Ticking Sound...All of these 22 had either 1 complete side of lifters and push rods replaced or both sides!
Mind You! If my Ram ever has this issue and the dealer says they will replace the lifters and pushrods! I will be placing a small micro camera in the engine bay! To record if they even tear into the engine to actually replace these parts!! I have a hard time trusting anyone these days!
Anyway! I read all 42 cases from start to finish... After Replacing all the so called moving parts that supposedly was causing this Tick! Not 1 solved the Problem!!! Every Hemi still had the Tick after the Lifters & Pushrods where replaced or supposedly replaced!
I did read a few articles of owners who were not Scared to switch to a 30Wt oil and reported back a quieter tick!
My eyes and head hurt right now!! Going to take a break! One way or the other I am going to find out what in the Sam Hill is causing this Tick!
Forgot to post this! Found this from 2010-11... Surely Chrysler would come up with a better designed Lifter by now!! If not? It's a pretty pathetic effort!!
Apparently some Chrysler engineers told David Vizard (see link below) that they had tested these lifters for 'anti-pump-up' at rpms up to 6200 rpm. A normal hyd lifter won't go that high without mods, so the Hemi lifters must have some internal mods.
If Chrysler made their Hemi lifters 'Rhoads Style' with internal bleed down, that would also potentially explain how an engine with a torque max at 4200 could still produce 330 ft-lbs at 2000 rpm and 300 ft-lbs at a (hard to believe) 1200 rpm.
See how the torque curve 'flips upward' in the 1200-1600 rpm range. That is odd, and might be due to lifter bleed off that is designed in to the lifters.
If the Hemi lifters are 'bleed down' designs, and if the quality control at their manufacturer is not superb - or if new truck customers are 'ruining' the hydraulic lifters by running them to 6400+ rpm on engines that have only a few miles on them - then it might be a 'root cause' of the Hemi tick.
If the Hyd Lifters collapse too much,
you would expect slack in the valvetrain.
Slack in the valvetrain would lead to
broken valve springs,
damaged rockers,
broken valves,
bad valve seats, etc
Other posts in forums have talked about the manual's call for 5W-20 oil in the 5.7 Hemi. A low viscosity, high film strength oil is a sign that someone is trying to deal with a 'tricky' hydraulic lifter requirement for lubrication. The narrow range of 5 to 20 is another sign that 'controlled leakage bleed off' must lie within a close range to something to work properly.
Chrysler has messed up on hydraulic lifters before, their first roller lifters in the late 1980's pre-Magnum 'roller' 318 had chrome plating that flaked off and the staking on the roller axle ends was not consistent.
What are the 'real world' implications of this?
1. Try to buy a Hemi with almost no miles on the odometer - then break it in gently yourself for the first 3000 miles with several oil changes to flush out small particles. No need to change the filter, just change the oil, perhaps every 500 miles. Don't used old fashioned ideas about how to break in an engine that was only valid back in the days of flat tappet lifters. Consider custom ordering a truck and tell the dealer you expect single digit mileage on the odometer when it arrives.
2. Pay close attention to the oil you use. Watch your oil pressures closely.
3. If problems develop in the valve train, always insist the hydraulic roller lifters be replaced too, no matter what BS the dealership throws at you.
4. Insist that all 8 cylinders valvetrain be brought up to new, not just the one failed cylinder.
5. Learn about Small Claims Court rules for your State. DaimlerChrysler is afraid of Small Claims Court because they almost always lose against a well prepared customer. Print out the Popular Hot Rodding article and be prepared to explain to the judge how this small part caused these high $ repairs and lost resale values. Know your state's Lemon Law too.
6. Don't even be the least bit bashfull about insisting that DC make your Hemi right and re-imburse you for expenses. DC top brass have admitted to Wall Street bigwigs that the 5.7 Hemi has been the 'Profit Machine' that has made them oodles of money. It costs DC less money to make a 5.7 Hemi than a 4.7V8 but they charge a $800 premium! The German honchos at DaimlerChrysler reached back into the American engineered Hemi 426 past glory days and pulled their chestnuts out of today's fire. Have they sent the old retired Chrysler engineers (like those profiled in this month's Hot Rod Magazine) any bonus checks to go with their pensions? I bet not.
If I counted right almost all of those that went in for replacement lifters were using the specified oil when the Ticks began!
Backwoods
Backwoods
Thanks, thats a lot to take in though. This whole thing just has me a little spooked, I bought a newer truck thinking I wouldn't have to worry about things like this. It's covered under warranty this time but if It fails again in the future or something else fails because of this, that will be an expensive fix. I called the dealer today asking them to save all the parts they replaced so I can take a look at them.
jwheeler
Washington
It happens. Unfortunately there are two in the shop I am at right now having cams put in because of lifter failure. It is not usually that common but it is a problem with the hemi. I have seen it a lot on cop cars. Likely caused by the high idle times.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
What I don't understand--> from Reading hours of posts of Hemi owners who have acquired this So Called Tick within a Very Short Time of owning their new Hemi's!! While still using the Specified Oil! Some have even heard and recorded the Tick while still on the dealers lot!!! A Totally new Engine!!! The Techs at the dealership would tell this is just a Natural Sound that the Hemi Makes!!
Most complain of a Sewing Machine Sound! Some Say it definitely sounds like a Lifter Tick! But everyone of the owners that I have read about who had the lifters and push rods replaced still had the So Called Tick afterwards...
I am going to keep at it!! Keep researching and asking questions!!!
I'm siting back and waiting to read about the first 2014 5.7L owner to aquire the Tick!
jwheeler
Washington
I put a set of lifters in one last week that had 2000 miles on it. It was a loud tick. It was a failed lifter.
It was fixed for sure.
There is a huge difference between a lifter tick and what is considered normal. When I hear people say "hemi tick" I assume they are just referring the noise that is made by the injectors. They are pretty noisy compared to most. That might be what people are referring to as the sewing machine noise. They all sound like that. But a failed lifter, or push rod, or rocker shaft definitely sounds different and there is something that needs to be fixed.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
If only 2K miles what caused this 1 lifter to fail?
1. Why was it just 1?
2. Where the lifters you installed they Same Type?
If so-->This issue just might return?
3. What exactly failed on this Lifter?
By the Way-->Thanks for sharing this!!
MADDOG
Living in a Firepit
6.4L HEMI
A smoothed cam lobe is not an unknown issue but it indicates either a material deficiency with the cam metal (casting bubble) or a material mismatch between the cam and the pushrod or a valve spring out of spec (too stiff).
Reactions: SyN
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
I would agree with you if the 5.7 Hemi had direct injection at 2,000 psi like my F150. You would certainly hear the injectors on that truck, but you shouldn't hear them on the 5.7 Hemi. Now open the hood and put your face down by the engine, yes...now you should hear them, but with the hood closed and at an arm length away you really shouldn't be able to.
