Exhaust manifold bolts.. the struggle
chri5k
USA
Diesel
One member in another thread is going with the Napa replacement manifolds. His mechanic told him they have a different design / materials that solve the bolt problem and have a 2 year warranty. I am only passing this along and have no first hand knowledge. The kits are ~$120 per side. Perhaps an independent shop in your area that uses Napa parts can get / install them for you and then you would have a 2 year warranty on the materials and whatever the shop offers for labor.
Tach_tech
5.7L HEMI
The last time we tried aftermarket manifolds the bolt holes didn’t even line up. We have only tried them once but that was enough to continue using our OE ones. I don’t know if they are all like that, just my experience with them.
Midnight Storm
One Badass Ram
Victoria, B.C Canada
If you have taken your truck in for over a dozen bolts to be repaired out of warranty, you’re probably going to end up saving money buying racing hart long tubes and a custom tuner.
Plus you get a way more awesome performing truck out of it!
Daddyhas2boys
Honestly the first time for me was 5 broken bolts total but I opted for the cheap route on ebay with long headers, mid pipe with y pipe...total cost for parts was around 400 i also changed the muffler to a flowmaster super 10 extremely mean and loud when coupled with long headers, keep in mind long headers require a tuner and tune so total i have around 1150 in it but no more broken bolts...ever
Daddyhas2boys
At this point the shorties should be done warping for good so another option is to have the original shorties machined at a machine shop and that should eliminate your broken bolts as well
clint440
Graham WA
Bolts are only part of the equation though. You have to fix what's causing the stress. Keep in mind shorties are cheaper, and not a lot of gain. Long tubes are better but only when paired with a tuner. Both the ling tubes and the tune are more expensive than the shorties. You could be close to $2k for long tubes and a tune, where the shorties are closer to $600
In agreement with above. My experience below:
I think I was around 1,400ish with LT Headers, tune, and installed muffler. (I did the header swap myself).
You can piece together something good to save some money if you are willing to do the labor, research, and sourcing yourself.
If you do the work yourself you are potentially better served with LTs. Get more real world satisfaction/results with a PIA job.
Justin33
All I know is I had the dealer look two times now and both times they say that none are broke. Maybe I think my engine sound louder than it really is but I also have a 2015 with 16k miles.
Lifted2wd
Lifted2wd
My 15 is throaty w exhaust and intake. You can tell a broken bolt when you start it up. The noise will go away when the engine heats up
Justin33
True just saying who’s to say they actually looked. I had a random whistle for awhile too and came across a post on here about it being the good or something.
Lifted2wd
Lifted2wd
Yup. Kinda like the dealer continuously telling me the tick was normal. New lifters. Its gone
jester139
Colorado
My 16 did this. I went with American Racing headers (long tube with midpipe) and I loved them. I used their hardware and had no issues. I had them for about 40k miles and abused that truck and they held up with zero issues. I did have to get an unlocked PCM and tuner, so it is a chunk of change, but worth it IMO.
