2012 Crew cab leaking????
RamBrosK9280
weve had unusally a lot of rain here lately today after only having this truck 2 weeks I lifted my back seat and there was puddles of water in each of the underseat storage. sucks!! need help please!!!
jwheeler
Washington
Remove the 3rd brake light. Replace all the bulbs so you won't need to do it again soon. And seal with clear silicone.
An example of something Ram and Dodge have known for years and never did anything about, the F_wking C__k S__king Bast_rds from hell.
crazy_luck
Minnesota
Could be worse - our ignitions could be failing and killing people...
Mines not leaking yet, that I can tell, but next weekend, when it isn't raining, I plan on sealing mine really well to make sure it doesn't start.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
The same issue on Ford F150.
Yup, this leaky 3rd brake light crap is all over the F150 forums. I was disappointed when I bought my 14 Ram Sport and started to read the forums only to see the same darn leaky 3rd brake light issue. Ridiculous.
I went ahead and bought LED light bulbs and sealed mine with silicone before it ever leaked. I didn't want to wait until I had a wet mess.
gofishn
Iowa
hemi 5.7L, 345 cu in
third brake light, donp't silicone it though, Google is yoru friend, research 3rd brake light and gasket. there is a thread where a guy shows how he used to strips, 2 different sizes, to create his own gasket for the third brake light. too tired to find it now. basically get some sticky door weather sealant, cut to sixe, run another one, around the outside of the first one and re install the light assembly.
not too complicated
Cheers,
Dave
BlownGP
Houston/Baton Rouge
not too complicated
Cheers,
Dave
Good idea, but silicone works fine.
Mines going on two years and no leaks.. Yeah and I live in Louisiana, we've had rain almost everyday going on a month now.
firemedic10584
Central Fl
not too complicated
Cheers,
Dave
I did this trick first on my 2011 truck...did not work. Went to the silicone seal method and worked flawlessly. First thing I did on my 2013 when I discovered it had the same issue. No issues now well over a year and a half.
Same here. Silicone solved it and had no further issues since.
soldiercowboy
Killeen Texas
Hemi 6.4l 4x4 Tradesman crew cab
Thanks go fish in got a 2014 2500 better check my seal and fix it before leaks still raining in central tx
Sent from my SAMSUNG-SM-T337A
MyOhFive
HEMI
how is it some trucks have this issue and some don't..
