2014 RAM 1500 Express Crew Cab
hodge-xj
5.9 cummins
Lol I’m always looking for sponsors! I could only imagine how much more abuse these trucks would take if the money didn’t come out of our own pockets.
I reckon you'd need a new frame bi annually. But watching what would happen would be priceless. Hell I'm back on stock 20s just to curb my desire to abuse this thing. Grandpa tires are a perfect deterrent.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Removed the SLF-140 coils and slapped my old Icons back with the Daystar 1" spacers.
I can tell the difference in the handling department as with the Superlift the rear had definetely more body roll, Icons can for sure manage the weight i have in a better way as the rear feels more planted everywhere especially around corners. Took the truck to my local testing ground to shake those spacers and make them settle. As expected the rear is back again to 41" (40 7/8" if i'm going to be picky :))
These are the spacers, plug and play just remove the factory isolators and plug this back in, they have the groove for the coil to fit it like a sock
48209022636_4040565ca8_h.jpg20190705_132903_HDR by RAM RSM, on Flickr
48209079022_672695f1a6_h.jpg20190705_132841_HDR by RAM RSM, on Flickr
No need for TB bracket anything, handles the same as before when the rear was 1" lower, axel is shifted 1/8" so the difference is nothing ill ever worry about.
1" lower with the SLF-140
48183671577_927c833824_h.jpg20190702_144340_HDR by RAM RSM, on Flickr
1" higher with the Icon/1" spacer
48209072812_e2757679e8_h.jpgUntitled by RAM RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Damn and we just had another shake couple of min ago, 7.1 this time same place as the 6.4 from yesterday in Crestidge,CA
revitupmoto33
Flagstaff
Ecodiesel
Felt this one rolled on for a while. Wont have mine in till next week, ordered up some heims to make my own trackbar, those will probably show up around the same time. Hoping to hit that 41
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Where are you getting your heims, Currie ?
revitupmoto33
Flagstaff
Ecodiesel
Ordered them from Barnes, thought about doing the Johnny joints but they are out of my budget to use on a trackbar. I started to price out how much it would cost to build upper/lower control arms for the rear using Johnny joints and would be about the same price as the Core 4x4 ones and those come powder coated. Here’s the website, they have a bunch of cool stuff on there (mainly geared toward jeeps).
https://www.barnes4wd.com/barnes4wd-products.html
buddy guy
alberta
@ram1500rsm , i've been eyeing those spacers too. seem like the cheapest I could get around here in Canada. They go on top of the coils, right? no modding necessary? saw a few people complaining on amazon they don't fit. any idea what they could be doing wrong?
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
No idea, but yes they go on top of the coil springs. Just take the factory isolators out and bolt this ones in, then put the springs back.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Got my new AEM 30-0334 delivered today
I'll get the **** installed prob this coming Sat, then i'll wire the WB inside, then to check and tune AFR with Hptuners.
48243167996_92f0506550_h.jpgUntitled by RAM RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I've been scouting the web looking to see if the Hellwig will hinder offroad performance and i haven't been able to find anything other than how awesome the rear feels like after install.
So i thought to find out if the rear can extend the same after i get the Hellwig installed
With stock Mopar 20mm rear sway bar
Tire to fender measurements (Falken AT3W 315/70/17)
Truck level at rest: 7 1/4
Max Droop tire in the air with the other side tucked in the bumpstop: 14 1/2
Total droop: 7 1/4
Have no idea if the Hellwig will shorten that out but in theory the outer hole should be the same as stock so we shall see once i get the thing back there.
48282830442_7e40538b7e_h.jpgUntitled by RAM RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Got the Hellwig installed this afternoon and It does make a nice difference in handling. The factory one is really another pos worst than the factory trackbar I must add in terms of wimpy factor. sometimes I can’t believe FCA gets away with this cheapy parts on a truck that is supposed to be able to tow 10k lbs.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
And i just went out for a quick droop test, happy to report zero performance hindrance in this regards, at least on the most outer holes. She was able to extend one leg in full at 14 1/2"
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Curious what your extension would be without a sway bar at all.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I never officially measured but i did the test to find out with and without rear sway bar
https://www.ramforum.com/posts/1812008/
I'll say the rear bar is good for prob 1/2" more droop. Not worth the loss in handling, and even if you're offroading at speed, the trackbar really makes such a dramatic difference both front and rear that it wouldn't be an improvement.
I also did the test without the front one, uptravel in this case you'll have 1.5" more uptravel, but at the expense of ****** onroad handling, and to be honest the truck didn't handle that geat at speed without the front sway bar, i guess if you're crawling then having no front will give you a little better uptravel performance
https://www.ramforum.com/posts/1985705/
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Makes sense why the drag racers remove the front end links, almost 2 more inches of front lift transfers a lot of weight to the rear tires for launch.
