545RFE 2wd to 4wd
klackmeal
California
I asked a related question on a different forum which leads me to this question: Is it really this easy to convert a 2wd 545RFE transmission to 4wd by simply replacing the “Rear Extension Housing” with a “Transfer Case Adapter”?
I ask this question due to the lockup converter (2007 1500 4wd 5.7L) failing to lockup correctly. I prefer to find a donor trans to rebuild. This will make for less down time for my truck.
K
klackmeal
California
HemiLonestar
Navy Badge Coast Guard
MD
Unfortunately it means you're still stuck with the RFE trans.
K
klackmeal
California
For the clueless, a skunk can be the perfect cat. At over 200k, I’m quite content with my RFE skunk. And, I do thank you for the assist.
