Drilled and tapped. The mounting options with the bracket, gave a solid option to bolt it in there.How did you mount the exterior box in that location?
Did you by chance get any pictures? i looked at mounting there, but i cant tell how you did the mounting?Drilled and tapped. The mounting options with the bracket, gave a solid option to bolt it in there.
I did not get pictures of just the bracket mounted see if my write up helps any. If I remember to pop open the hood tomorrow, I will PM you some pictures. Did you buy the same one I did?Did you by chance get any pictures? i looked at mounting there, but i cant tell how you did the mounting?
Yeah got the same one because of your pictures. i have mine mounted, buts its a pain to get to so im going to move it. its between the battery and firewall. the relays on mine dont seem to like my diode dynamics ss3 pro's, relay coil lets off a high pitch tone when they are turned on.I did not get pictures of just the bracket mounted see if my write up helps any. If I remember to pop open the hood tomorrow, I will PM you some pictures. Did you buy the same one I did?
https://www.ramforum.com/threads/trailmaker’s-pw-build-thread.161909/page-2
Sounds like a grounding issue.Yeah got the same one because of your pictures. i have mine mounted, buts its a pain to get to so im going to move it. its between the battery and firewall. the relays on mine dont seem to like my diode dynamics ss3 pro's, relay coil lets off a high pitch tone when they are turned on.
Can you link to what you ordered?
That's the one i ordered but just the bracket. Maple off-road looks great but almost 400$ for a light bracket is crazyI think this is the Vison X product that was referenced...
https://www.visionxusa.com/shop/winch-fairlead-mount/
