5w30 Restore and Protect Valvoline?
bereta1
Ky
2016 Ram 1500 5.7 H , 120000m. Uses about a qt between oil changes. Just wondering if this would be a good product to use in my engine. Supposed to clean it up.
that will clean rings from the bottom, redline si-1 will clean from the top. If it is carbon on rings both of those products are probably the best for what they do.
huntergreen
Marine Corps Navy Badge
How long do you run your oil for ?
EdGs
FL
I'm running it now in my Hemi, after doing my cam and lifters, now have 213,000 miles, at the point of changing out my oil filter and topping off R&P after 3k miles.
I pretty much replaced and cleaned every thing from the piston tops up, the bottom end was all I didn't touch.
Gonna change the R&P again at 215k another filter at 217.5k, and then hopefully RedLine 5W-30 from there out.
I've been exercising the skinny pedal as much as possible, too.
