8.4 Uconnect in Canadian ram
calikeegzk
Puyallup, WA
Hey all, so I have a Canadian 2013 ram 1500 sport that I recently installed a 2018 US 8.4 Uconnect for Apple CarPlay but it keeps trying to open the Uconnect assist app and will keep trying over and over and it interrupt my CarPlay and disconnects it. Has anyone had this issue before? Is it just a screwed up radio? Or so I need to put a Canadian radio in it because it’s a Canadian truck? Any help appreciated. Thank you
RamDiver
Marlborough, Ontario Canada
2021 DS
That sounds like a pooched Uconnect radio to me but @SitKneelBend will confirm.
I wonder if the contacts for the assist switch shorted or they work with normally closed (NC) switch and they're currently open.
I will investigate tomorrow if SKB hasn't answered before my return.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If I had to guess, you are experiencing ghost touches from a screen in the first stages of delamination. I've successfully stopped these touches by improving the passive cooling thermal material inside the radio and adding cooling fans (~$30). Conversely, you can replace the screen ($150-$250).
C
calikeegzk
Puyallup, WA
Hmm. I've replaced the screen when I first put it in in October of last year. Bought it off Amazon and replaced myself. Could I have messed something up internally in the process or did I just buy a bad screen?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Could be the screen itself. DO you have any pictures of the back of the screen before installing?
That's still one of the best mods i did on the wifes old 2019 Challenger SKB,adding 2 cooling fans to it.Thank you again for idea :waytogo:After adding the fans,it never had the "black screen of death" again that the 2019 1320 Challengers are famous for
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Yeah, I feel it actually improves performance. Always very snappy and responsive (also super cheap mod)!
I did the thermal sheet upgrade that you also recomended,and there was a noticable differance in how hot the radio felt to the touch after doing both your reconmended mods. Afterwards the radio never once had the black screen,which it had been doing fairly often on hot days up till then. If i'm pulling another head unit out to swap the screen on,it's also going to get both mods at the same time,as they appear to help keep the Dodge head units happier. :waytogo:
I went looking for your thread on the mods,but can't seem to find it,if you can find it,i think you should link it to this thread,as it's a very good upgrade to do if you have the head unit out to replace the screen
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It's buried in other threads. I never actually made it it's own thing (but I should). I'm glad that it's more than my anecdotes on the benefits of it though!
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
@Wild one @SitKneelBend ....
My notes I've saved for it with links.
Get a genuine/new (LA084X01 SL03) Screen/Digitizer assembly (definitely not an SL01 version… SL02 maybe) ~ $150-$300 and replace it yourself…. Or send it off to United Radio (Peachtree GA) or NavRepair (FL)
DavicArm_0 (C&H Car Stereo)
is reputable << VIDEO >> How to Fix Delaminating OR Bubbles 8.4" U-connect VP3 VP4 LCD MONITOR Touch-Screen Radio Navigation
Reference’s to help (see SitKneelBend’s info at RamForum where you can find it)
>> SitKneelBend is a great resource for help replacing the screen and gave me pointers. I donated my old screen to him to play with trying different ways to repair it. If you can, please do so.
How To: Install a 2018 4C (UAQ/UAS) Radio POST 3051
>> He recommends replacing the original Thermal Pads while you’re in there, I did (Arctic Thermal Pad 145 x 145 x 1.5 mm - Silicone Based Thermal Pad).
>>> Some of my posts 8.4 Uconnect touch screen delaminating Post 209 and Post 223 about it.
Also recommend this...
Amazon.com: 2X BROTECT Matte Screen Protector for Uconnect 8.4 (Ram 1500/2500 / 3500 / Chassis Cab), Matte, Anti-Glare, Anti-Scratch: GPS & Navigation
www.amazon.com
Other Info
RamForum - UAQ/UAS Digitizer Replacement Steps
YouTube - 2017 2018 HOW TO REPLACE Replacement 8.4" Uconnect 4C UAQ LCD MONITOR Touch-Screen Radio Navigation
You Tube – (Factory Radio Parts) - How to disassemble and repair the Uconnect 4 & 4C 8.4 Inch Touchscreen UAS & UAQ Panasonic Radio
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
www.amazon.com
Other Info
Good looking out Brother!
It would be a very good thread if you did a write up seperately on your fan and thermal pad upgrades.I think you should do one,as i found it very informative and very helpful in fixing the screen in the wifes Challenger
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
@Mpgrimm2 did all the work for me already! But I take your point...I could easily take the cross reference he made and start a new thread.
I think a seperate thread with your pics and write up would go over good. I slipped up as i never took any pics of the fans i mounted in the Challenger when i installed them,and i probably should have,as the cars been sold,and i doubt i could talk the new owner into pulling the radio out to get a few pics now.
