Mbrigh3
IG: Stormtrooper_5.7
Dodge/RAM/FCA didnt make the transmission, so ....
It still represents their product. Dont get me wrong I love my Ram I just hope it can stay out of the shop this time!
FWIW the trans they chose is pretty darn good. Used in a ton of high end applications and seems to have a very good track record.
Granted, there will be lemons, but overall I think its a fine transmission. Probably the best autotragic Ive ever owned. Still has quirks, of course.
OTOH I start to wonder if its FCAs paranoia about the trans that makes these issues never really get resolved (Ive read multiple times they have basically been told "s/w update, replace valve body or replace the whole thing" are their only options)
Personally I think its all software. New valve body or even a new trans "fixes" the problem, until the s/w learns bad values, bad habits, whatever. Then the issue "returns" evne though it was only temporarily gone because the valve body or trans replacement essentially reset all of the s/w values.
My G37 is very similar and its quite noticeable if the battery dies, especially if it dies while starting the car. The trans shifts like crap for a few days after that, then eventually comes back to what it was before the battery issue.
So my 2019 classic ccsb has been in the shop for three weeks now. They have been fixing a power steering failure issue, first visit when it was in the shop for a week they replaced the power steering gear. 2 weeks later it began failing again while driving (no power steering assist). Turns out there was a corroded connector below the truck and ac condensate dropped onto it because it was fitted wrong by company itself which was causing communication issues and leading to electronic failures.
Anyway, in terms of a loaner, I’m in a 2019 1500 classic crew cab 4X4 regular 6 ft bed which has 24xxx miles on it and it runs great. I tried hard in the last 3 weeks to simulate the bump in my truck. No thuds/ bumps from the transmission. I looked under and it hasi felt knee a solid drive shaft going directly from the transmission to the rear diff. The truck feel smoother under acceleration too. Possibly the two pc. drive shaft in my truck is the culprit. I’m waiting for the dealership to revert back with their diagnosis. Will keep you’ll posted.
You clearly know a lot more about transmissions then me! Im just hoping the new free transmission fixes my problems. I miss my truck lol
Did the new tranny fix your issue???
My is back in the shop after they Flashed the ecu, no help
They replaced the valve body - no help
Now theyre gonna replace the tranny.
YUP! the transmission fixed my issue! she runs great now
How long did it take your dealer to get approval from fca to repair or replace your trans? I'm going through the process of getting mine done at the moment.You clearly know a lot more about transmissions then me! Im just hoping the new free transmission fixes my problems. I miss my truck lol
Mbrigh3 good to know that the new transmission has fixed your problem. How many miles have you put on the truck with the new transmission? No jerks or bumps when coming to a stop or taking off?
Mine is back at the dealership and they are diagnosing the issue again.
Well don't sweat it because hopefully you end up with a new tranny and a new driveshaftMy 2017 1500 Limited is at the dealer now for this issue dealer is installing a new drive shaft.
I'm bummed because I see replacing the transmission fixed the issue not the drive shaft.
First dealership service manager refused to fix anything on my truck. Said it’s a ‘normal operating characteristic’ and that there is no fix and nothing they can do. They say nothing wrong with the transmission or driveshaft. Service advisor told me in confidentiality that they didn’t even look into the concern, the service manager didn’t want to deal with my issue. I have reported this to FCA and will take it up with the owner of the dealership as well.
So I got with FCA and they got me into another dealership, where the shop foreman rode with me and he acknowledged the issue. So first thing to be changed will be the drive shaft. If that doesn’t fix the issue it’s the transmission which is a lengthy process.
He said that any packing any grease or anti seize into the splines would reduce the play but not really solve the problem. According to him it’s not the driveshaft, because whenever you switch to drive or neutral the truck will thud and bump with a bad drive shaft.
For me it started as red tape.9 working days from when it was diagnosed. Now it's back ordered parts so it'll be almost 3 weeks to get those now by their estimate and then 3 or 4 days to get it to the specialty shop repaired, then back in the truck. I'll be around 6 weeks down. If it was quick approval and parts were available it would have been about a week.What is it about getting the transmission replaced?
is it the work itself or the red tape of being able to get the work done?
