The whole ethanol/no ethanol thing is hilarious to me. In the states, we have been blending up to 10% ethanol in our gasoline since the late 1970s. It wasn't necessarily advertised at the pump like it is now but if you are driving a vehicle designed since the 1980s, IT IS DESIGNED TO RUN ON 10% ETHANOL blended into the gasoline. Will it hurt your vehicle to run 0 ethanol gas? No, but for the additional price of 0 ethanol gas, there is not enough benefit to regularly run it. The research shows most vehicles will gain 2-3% in fuel efficiency on 0 ethanol, but the cost is usually 10-15% more per gallon. Also, the alcohol has a lower flash point and burns more completely than gasoline so you pick up a little power with ethanol, that's why drag cars run methanol injection.
Now, if you plan to store your vehicle, watercraft, lawn equipment with gas in the tank for longer than 45-60 days, I would recommend 0 ethanol in that case as the ethanol does absorb moisture from the air and any amount of WATER in your gas is far worse your fuel system than the 10% of ethanol you will find.
