A Catch cam is a must
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I actually like being able to unscrew it better than having that valve...It is cleaner this way.
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
The only issue I have with the valve on bottom is that some people will not empty it and dispose of the oil properly. They will just simply open the valve, when and where, they feel like it.
HLram
2012 and 2007
Hemi 5.7 in both
good point.
CAP LOCK KID
Ontario
2013 Sport QC 4x4
5.7L HEMI
Agree with the dump it anywhere statement.
I could also see someone forgetting to close it. Wonder what the would feel like?
I like being able to unscrew it. Also lets you see what's in there and inspect it.
audio1der
Airdrie, Alberta
The more I look at them, the more I like the Moroso design with the valve, and where they locate it.
I would add a straight thread>barb fitting off the bottom of the can and run a length of line to the bottom of the splash shield, and put the valve there. It may get dirty itself, but with a length of hose it would dribble for days after draining it there were nothing at the bottom. It would be MUCH easier to access & drain neatly IMO.
97RamSB
An oil catch can is used in turbo applications, or high-performance race applications where excessive blow-by (leakage past the piston rings) of air and fuel vapor occurs. This creates a positive pressure in the crankcase. Engine manufactures have placed a valve on the engine block which releases this pressure. This valve is known as a PCV (Positive Crankcase Ventilation) valve. During engine operation, blow-by gases, as well as oil mist from the rotating components of the engine, pass through the PCV valve and are routed back into the intake for the engine to burn off. However, some of the oil mist and other products settle along the engine intake and over time form a "gunk." The oil catch can collects the oil mist and condenses the fuel vapors while allowing "cleaner" gases to be passed back into the intake. Typically the blow-by gasses are passed through a wire mesh, which give the vapor droplets something to adhere to. Since the oil catch cans condense the vapor portion of
the gasses, they will need to be drained periodically of all the oil, fuel and other contaminants.
GoldDot
Billet tech screw on can style is the way to go. During the winter there is some kind of thick oil substance that sticks to the inside of can. Takes a paper towel to remove.
97RamSB
Can these be installed on a 96 5.9L? Just curious I'm gonna play with the topside of my engine this summer and was considering this.
They can go on any vehicle. I actually make an sell these
audio1der
Airdrie, Alberta
This post should be a sticky. That is the most clear explanation I have read anywhere.
Lawhand
Baton Rouge, LA
does the synthetic oil slip past the rings more? cause im not having that much in my catch can running regular oil every 2k i have about 1/2 a cup.
HLram
2012 and 2007
Hemi 5.7 in both
I have wondered the same thing myself.
audio1der
Airdrie, Alberta
Do you want that 1/2 cup going back into the engine and being burnt off with your fuel? Yuck!
So would a catch can be a good idea on my 74 big block Chevy? It's in a Corvette with aftermarket valve covers that did not have baffles for the PCV. I have a push-in breather style PCV valve in there now going to a vacuum source on the intake manifold but I'm not sure if this setup is ideal. How would this be added?
Does it have a carburetor or EFI?
