AEV 4” Dual Sport Suspension installed.
DamnRam1500
New Hampshire
2016 Ram 1500 Express 4x4
View attachment 222625E9551E1A-134F-4F4C-96E9-C21874414F0B.jpeg B241D4B4-AB2B-4386-907E-82CC42BD2F76.jpeg C8FCE507-650A-43E4-B3AE-0EBFACA574E4.jpeg D409A8A0-846F-4293-AA81-91B783450EF2.jpeg
After two weekends of hell I finally finished installing my lift, as well as the CV axle repair kit from Rick Roods driveline in NS Canada.
The biggest problem I had was the drivers side lower control arm cam bolts were badly seized in the bushings. I spent over 10 hours trying to get them out and they wouldn’t budge. I ended up buying new bolts, nuts and a new lower control arm (no time for replacing the bushings in the control arm)
the differential repair kit was a breeze and was done in about an hour once I had the suspension removed and full access to the differential.
I loved my factory sport wheels but I didn’t want to use spacers anymore. I opted to buy the AEV Delta 20x9 wheels which are designed for this lift and truck with a 35x12.5” tire. Though I’ve had 35s since I did the rough country level kit it looks much better now with the tires not stuffed so much.
Before
DamnRam1500
DamnRam1500
New Hampshire
73145260-7CB2-4A62-829A-A59F81B4580E.jpegDF47BA5E-ADD6-43BC-B5C2-F8324D953F14.jpeg The rest of the install went relatively smooth. Here are the new seals From the Rick Roods kit that go over the ends of the CV axles and on to the shafts.
DamnRam1500
DamnRam1500
New Hampshire
JB1
Houston, Texas
Looks great, I like those wheels too that's a nice setup.
Did you have to do any cutting?
What setting or notch are the Bilsteins set too?
DamnRam1500
DamnRam1500
New Hampshire
I had to cut the flare off the factory LCA mounts to clear the alignment bolts and one of the cross member tabs gets cut off.
Sheapdog
Jackson
DamnRam1500
DamnRam1500
New Hampshire
It’s an Eotec EXPS2 and I love it. The forward assist? Never had to use it but it’s just a mil-spec FA.
DamnRam1500
DamnRam1500
New Hampshire
How do you like that skid plate, it looks good in the pics
I love it, it’s the backbone of the whole front end. It has built in crossmembers to replace the rear dog bone style x member and the whole front differential sits in to the skid plate with custom brackets and bushings. That combined with the custom made knuckles drops the front end but keeps all the angles at factory geometry. It’s a really well designed kit but unfortunately it’s discontinued.
They are focusing on the 2500/3500 platform for Ram as well as Jeeps, Colorado/Canyon and Tacoma.
Reactions: JB1
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Came out good. Truck looks really Nice flexing on that rock
phorrestphire
