AFE Power Exhaust for 2019 PW?
olyelr
Kewadin MI
There is a good chance it will bolt up just fine. Although also a possibility there have been some minor changes that would make it not work.
Hard to believe they haven’t actually tested one out yet. Wth.
Nick@GotExhaust
Preferred Vendor
SC
I double checked and cant find anything confirming it would fit. I would guess it would fit as some of the other brands that have exhausts for 19's fit pre 19's.
If you would like to order one message me. We can offer you a great price on it and we have it in stock right now!
Rated R
Rated R
USA
Thanks Nick. I'd want to make sure it'll fit beforehand...:cheers:
1pieceatatime
Mitten State
6.4L
Nick, where does the exhaust tip end up on this guy? I crunched my OE exhaust outlet on a rock ledge in Moab a few weeks back and want to replace it - but I want to do something that tucks it up out of the way more than stock.
olyelr
Kewadin MI
Cut the resonator off as close to the resonator as possible. Then add a short tip to the pipe. Done. Tucked up out of the way nicely, and far enough down that it wont melt the wiring harness on the back bumper.
olyelr
Kewadin MI
Or, if you want it, just cut the last of the pipe off after the resonator and leave it at that.
Nick@GotExhaust
Preferred Vendor
SC
The AFE exits like stock.
I recommend for you to pick up a muffler kit like one of the ones we offer from Solo Performance then just delete the resonator as mentioned.
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Nick, It there a 1-2 hp gain when doing this? Seems like back pressure would weaken and effectively give a bump in HP.
Nick@GotExhaust
Preferred Vendor
SC
It will outflow the stock muffler and give a small increase in hp. That being said the 6.4 has a horrible y pipe that is very restrictive. I wouldnt worry about back pressure as long as you still have that y pipe.
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
thanks you.
I wonder if that’s part of the reason the Dodge Durango was able to get 65 more horsepower of the same engine last year?
olyelr
Kewadin MI
thanks you.
Different motor.
Although I mean that loosely.
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Different motor.
On 2017-18 Valves are the same size between both motors (2.138/1.654). Compression is lower by about 1 point, 10.9:1(SRT) vs. 10:1 on the Ram. Apache head design is basically the same for both motors except for material (356 Aluminum on the HD) and redesigned cooling jackets. Tech Authority lists the cam lift and duration for the HD motor, but at a glance it seems unlikely to be 100% accurate. Especially considering they appear to mimic the SRT cam specs. Yes, the truck 6.4 has different heads, cam & intake manifold
Throttle body however is the same on the 5.7, 6.1 & 6.4
So it leaves the exhaust to make up some hp.
olyelr
Kewadin MI
Alright. So your saying they are different? LOL
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
I was looking to do a few mods to gain a few hp. I read here on the forum that the sole delete made the driver feel a difference in acceleration.
Rated R
Rated R
USA
Just concerned about drone. Sound is fine but it's that resonant drone that really sucks.
