AlfaOBD Support For 06~12 Rams
Earl73
Tucson
Any update on this? Curious, as I need to replace my WIN module too.
There is a new update out, and it let me send the secret key from the WIN (old one) to the PCM, but not from the PCM to the new WIN.
It still says that the requested operation is not supported by the module. I'm not sure why it would allow it to go one way but not the other. Need to spend some more time fiddling around with it I guess and maybe send in another debug log.
Rustyraindog
Spanaway, WA
2011 PW
Shout out to Alexey at support for getting my issue resolved! I managed to connect to different modules and got what looks to be the configuration file CCN_info.log.
I did manage to program it so my fog lights stay on with the high beams. Not sure I want to do DRL as the app says it is irreversible. Now to learn where to change the tire pressure info in the system. So far I am in awe how in depth this app goes into the system! Can't wait to see what I can do with the 2014 Cherokee also.
I love that I can trigger devices to test them also, that is just cool AF!
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
I was able to enable and disable DRL on my 06 without a problem. Just didn't have a way to make it switchable like newer trucks do.
Sent from my SM-T500 using Tapatalk
ManualCummins
Cummins 6.7
Does anybody know how to turn on puddle light and turn signal in the mirrors on a 2009 1500
If you know what settings to turn on let me know thanks
aimvee
CA
Vehicle config 2: mirrors contain signal lamps
Vehicle config 2: door lamp configuration
Puddle lamp
Sent from my SM-G965W using Tapatalk
Caje
I have a 2012 SLT, I did all the steps. Still no DRLs. Thoughts?
aimvee
CA
Try this
Under DRL configuration set it to Canada.
Set lamp location to highbeams (or whatever you want)
Drl drop out - yes
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
Did you check with truck in gear and E-brake off? DRL is not on in park?
Caje
No, I didn't with the e brake off. Trt in the morning. Thank both of the answers
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Yeah they go off with the E brake. Makes it hard to check if they’re working thats for sure lol
Caje
Success! Did not think about the E brake. Thanks
Caje
I saw a part on bed lights. Is there a wire diagram and Alphaobd to add?
aimvee
CA
Hey guys.
I posted about this before but got nothing back.
Trying to activate the heated seats in a 2011.
Switch panel has been added.
Seats are from a 2017. All the modules plug and play. All fuses in..
What am I missing..
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Hey guys.
What am I missing..
I’d make 100% sure all the wiring is there. Between the fuse box and dash, dash to switch, switch to HSM, etc. Some of these trucks come with wiring preinstalled in SOME areas but not in others. It’s possible the dash harness may have the heated seat wiring already, but the harness that goes to the fuse box does not
Were you ever able to connect to the HSM using Alfa? What happens when you push the heated seat buttons?
aimvee
CA
I'll have the truck again in 3 days.
No I couldn't connect to the HSM .
Dash switchs do nothing, But the green "back light" cones on.
Trying again on Friday with a different seat module but it's from the same year
Rustyraindog
Spanaway, WA
2011 PW
Is this the correct field to rest the threshold for the TPMS lower? I want to set my tires at 45PSI and don't want the low tire pressure warning on the dash.IMG_20210124_115704065.jpg
aimvee
CA
Is this the correct field to rest the threshold for the TPMS lower? I want to set my tires at 45PSI and don't want the low tire pressure warning on the dash.View attachment 235150
Yes, that's it.
Set it, than drive it.
IF, that's does complete it.
Connect to "WCM" under the RF-HUB and "Reset WIN configuration".
You'll need your 4 digit code for this.
Either go to dealer. Or get it from "Chrysler pin puller". It's 15 tokens to get your PIN number. And first time using the app you get free 15 tokens so it won't cost you anything
Joey93
