Falcon1772
- Oct 23, 2017
- 72
- 18
- 2014
- 5.7
nvm figured out how to disable my warnings. had to pull the 40A and 20A fuse
I still cannot find a way to disable the TPMS service message, anyone with a RAM 1500 figure this out? I got the OBDLink MX+ adapter also
I am trying to figure out how. I can turn off the light but it comes back.Can you just turn off TPMS to get rid of the service message, I did that before, then decided to just adjust the tire pressure.
In Alpha OBD and for TPMS which Select: Body Computer should I be using for a 2500 2018?
I do not see anything int he list for a 18 ?
Sent from my SM-N960U1 using Tapatalk
Can you find them?Don’t have my notes with me but I seem to remember I disabled advanced TPMS, and basic TPMS.
Either one is fine.Ive got a 2017 1500. Should I be using Body Computer: MY2013-17 PowerNet or Body Computer: MY2016-17 PowerNet? Thanks
Either one is fine.
Can you find them?
Can you give me exact locations of these settings? Thank you budIll check later this evening, it’s only 1:30 pm here in Alaska, so its going to be a few hours
Edit: I changed premium TPM System present to : not set, Base TPM System present was already not set, these basically turned the system off. I then turned the base TPM system to set. Waited a few days (was hoping to see the pressure displayed in EVIC but no luck), then just reset it and adjusted the pressure threshold so the low pressure light didn’t come on.
With a faulty tire sensor you would probably just want to turn the system off.
ya tested the light and light socket it worked but pluged it in and don't work.have to test plug to see if theres power thereThe glove box light? As far as I've read, that one "just works", there are no settings for it. You just plug the light unit into the plug that's already there and you're done.
-K
Every one I have seen already had power running to it as Kad stated. Not sure what going on in your case but definitely strange.ya tested the light and light socket it worked but pluged it in and don't work.have to test plug to see if theres power there
