AlfaOBD
dwalk19
NY
cummins 6.7
i'm sure this has been covered but if i upgrade my instrument cluster, can i change the mileage to my trucks actual mileage with the alpha tool, or will it need to be sent out and programmed,,, thanks
Sent from my SM-G935V using Tapatalk
1500ram12
5.9L Cummins
Yes you can program mileage and hours. You'll most likely get a "failed to complete" message after but it will program them. There is a video by @BigDaddysHouse on how to do it
2018 2500 6.4L Tradesman
Parker675
Dallas GA
Mine programmed the mileage first try. Said failed but still did it. However I'm still unable to change my hours. Always fails and doesnt actually change. Dev is working on it. Truck is a 2013.
dwalk19
NY
cummins 6.7
thanks, just watched the video, i'm looking to upgrade mine on my '17 eventually, thanks again
Parker675
Dallas GA
New update out. Still haven't been able to change my hours. Got a procedure completed message when turning the key to accessory instead of on but no change in the actual cluster.
big daddys house
Hill Valley
I had some people comment on my channel. Few have said when you put the key in (the first click) ACC position and then fire up AlfaOBD.
It has worked for some... Give it a try let us know if it works for you.
Sent from my LG-LS995 using Tapatalk
kip eaton
texas
New to Alfa trying to upload a copy of my BCM to google drive keeps telling me not signed in to google account ?
northvibe
Minnesota
DRLs should turn off if the truck is in park or the parking brake is set.
Depending on which lights you have selected as your DRLs will vary when they are on but normal light function will take precedence over DRL operation. I'm using the dedicated set of DRLs, they will turn on if I remote start or turn the running lights on even if the truck is in Park.
As @crash68 is correct. If you have the lights in the on position or on the parking lights the drl's will be off. If you have the switch in the auto or off position the drl's will be activated once in drive/neutral or reverse. The parking break deactivates drl's.
Thanks! I had dropped off the truck for new tires and saw in the window my lights on, even with the light switch to off. But you are right, when you put it in Park, the drl's go off. All good!
aimvee
CA
Anybody know what this ' dead hole is used for'?
It's not the little LED light oh, you can see that above the rear window control359ae3f9e143f3030217c798bb2079f8.jpg
Sent from my SM-G965W using Tapatalk
aimvee
CA
I just read it's possibly for inside temperature control for the trucks that have Auto Temp on the hvac
It's not the ATC temperature sensor, that is on the lower dash panel on the driver's side. It's not the humidity sensor used in the 1500s either, that is against the windshield
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
In 2009 to 2012 models there used to be a sensor there that looks like a camera. It is no longer used but they use the same mold except the hole is plugged.
It's a great place to run an external microphone for those with aftermarket radios.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
In 2009 to 2012 models there used to be a sensor there that looks like a camera. It is no longer used but they use the same mold except the whole is plugged.
I was thinking of moving my microphone for my UAQ there to see if Google could hear me better.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Just go slow drilling out the plug (start small and make the hole larger in steps). If you do it right you can friction fit the microphone in place.
It's nice because even if you remove the microphone the hole is recessed. It's angle also means the microphone points somewhat toward the driver, the bell shape acts as somewhat of a collector of sound.
For larger microphones, it leaves enough area behind for the wire to run through and then you can surface mount the microphone.
Parker675
Dallas GA
Tried it. Still no luck. Guess I'm just screwed lol.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
New app update just a little while ago,
2.1.7.5. Maybe that will help those with problems.
enolS
NE Ohio
Doesn't seem like this Alfaobd update fixed the google drive upload. However later I'll try a more in depth, clear cache etc login.
