Same boat all my lights are on lol tried following the alpha obd directions with no success I'm obviously doing something wrongDid we get the tire size change figured out for 2019 trucks?
Sent from my SM-G965W using Tapatalk
Try the key in different positions too.Need some help here! Got a 7" evic and can't update the mileage or hours. I've been reading this thread and made sure both the app and mx+ software are updated. Tried to do the Vin update and it wouldn't take either. Any ideas or help would be appreciated.
Meant to put in that my truck is a 2016 ram 2500 outdoorsman.
Your going to need to verify the HIDs work, unplug the headline +12V connection and power it directly from the battery. Also plug your headlight bulb back in to test if you have voltage at the connection.Hi I need some help lol I installed HIDs into my 2019 classic with projectors, I also installed the Gateway Bypass harness. I loaded up AlfaOBD, selected my2019. I tried two things, I tried changing the "VehConfig 3-High Intensity Discharge Headlamps" to Yes with no luck, Low Beams never turn on. I also tried enabling "CBC Features-LED Low Beam Lamps Present" with no luck neither. I tried having them both enabled also with no luck.
I know the changes are taking affect, cuz I could see it in the vehicles Logs that this were enabled. Why aren't my Low Beam HIDs turning on?
I finally put my old halogen bulb in. It turned on no problem. My HID high beams work fine. I haven't had the chance to try the ballast/bulbs I was using for the lows. Just seemed odd that both ballast/bulbs for the lows would not work with a brand new kit.Your going to need to verify the HIDs work, unplug the headline +12V connection and power it directly from the battery. Also plug your headlight bulb back in to test if you have voltage at the connection.
I HAVE BECOME AN EXPERT IN THIS!!! Any led bulbs will work. For signal/tail lights make sure you have the SWITCHBACK bulbs ordered. That is the equivalent of our 2 filaments in one bulb for those who don't know. Standard 3157 led wont work must be switchback 3157 or whatever the bulb number is. Next make sure you enable combined rear lighting in AlphaOBD menu. This tells the truck that both the brake and signal light is the same bulb. Thats all I had to do but went one step further and enabled led brake light and led signal settings. No more codes for me!
For error on the middle brake light make sure to enable LED CHMSL. It sounds stupid but took me forever to figure out this meant center high mounted stop light lol. No more code there either
have switched everybulb in truck now to LED including fogs/highs/rears, signals and even interiors. I came to forum tonight to get info on last error for dome light but I am sure I will find the answer lol. Anyway I have totally figured this out if anyone needs help. Even did a successfull cluster swap from 3.
PC version of AlfaOBD works fine with me, but it is highly recommended to use OBDLink MX. Can't speak for that adapter.New to alphaOBD but I've used Forscan for fords a bunch. AlphaOBD seems way easier.
Of course though I can't get it to read my OBD interface. lol
I'm using the PC version.
This is the one I use for Forscan. I just have to switch back and forth the HS and MC can when I use it
I might just have to use the android version and use he OBDlink MX
I had the exact device for ForScan and it didn't work either...I agree that AlfaOBD is easier - likes tons easier...I hated having to do the hex conversions on items that weren't 'text' options...New to alphaOBD but I've used Forscan for fords a bunch. AlphaOBD seems way easier.
I'm going to be the stubborn one and ask a question that's been asked since 2009 because I refuse to accept defeat haha. So I don't guess there is anyway with all the wonders of Alfaobd that anybody has figured out how to get high idle on a truck with a G56 in it have they? I have read til my eyes have bled and haven't found anything concrete other than a concrete block to get my truck to stay in high idle when I need it to. Beating a dead horse I know but refuse to believe it cant be done.
Hi all, new here and just picked up a 2018 Ram 2500 CC 6.4L today. I have played with AlfaOBD on my 09 1500 4x4, but wanted some clarification as I have searched and not found a definite answer. I see on 2018+ we need a security bypass cable. Is this needed for ALL functions of AlfaOBD? Can I use it to view and reset codes without the cable? Program new FOBIKs? Thanks in advance!!
You can view and reset codes without the cable. Otherwise you need it
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
Thought that might be the case. I'll order it up, as I have already ordered an OEM remote start kit for the truck. Thanks for the confirmation!!
Sent from my SM-G973W using Tapatalk
I got the MX+ and using a laptop running Win10...What issues I've had seem to be 'user' related' or 'DOH!!!' moments...
