Yes...I believe it's under Settings, then Lights, on your radio...I don't remember the exact location after that, but you can change it...OK, so hear is a good one I heard from a friend is possible on other makes of trucks. When you hit the unlock button on the fob you will get approach lights currently. I do have the tow mirrors with the puddle lights and all works well. My questions is about the timing of the lights and how long they stay on after a unlock fob push. Can the timing be changed for the lights or puddle lights to stay on longer after an unlock?
Been mentioned a 100000000000 times already but apparently the mods are not going to make it happen.
I use the OBDlink MX with a laptop AND forscan - 3 different laptops and 1/2 dozen different FORDS mostly late model pickups and never had ANY adaptor issues
my point is you can get the MX and use the PC version for both FORD and RAM
Oh, that's good to know.
What's the difference between MX and MX+?
You can't seem to the MX anymore. I did find some cheap knock off on ebay.
While MX+ supports iOS, AlfaODB does not...Mx+ supports iOS.
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
I don't believe so but their should be no I'll effects of its set to LED that I'm aware of.I just changed the cargo lamps to led. Is there a way to tell alfaobd to change cargo lamps to led, but leave upper brake light as non-led?
Sent from my SM-N975U using Tapatalk
Don't go with the knock-offs and it doesn't look like the MX is available for sale from the manufacturer anymore. MX+ is the way to go you won't be sorry.
Pin not needed on newer 19+ models for changing tpms
LX works and is available.
MX+ only needed if you want to use other than AlfaOBD on iOS or need a VIN locked license for a GM or Ford vehicle. MX+ includes a single license for either.
The LX is the same as MX and MX+, except it can’t do Ford medium speed or GM single wire canbus, and no iOS. Otherwise, all three are exactly the same as far as AlfaOBD and our trucks are concerned.The developer wrote the program using MX and recommends the MX which is now the MX+. Use anything else at your own risk. Bypass is required for everything 2018 and newer. The majority of users here are making their changes with the MX or MX+ so if there's a connection issue or problem and you're using something different the knowledge base for help would be limited.
They all use the same Bluetooth. It’s not a good choice for those that are going to use it across different vehicle brands, but strictly for FCA vehicles and AlfaOBD, they all function the same.Is the speed the same? I thought some here had issues when doing the 7" EVIC upgrade.
https://www.obdadvisor.com/obdlink-mx-vs-lx-review/
