AlfaOBD
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
Locked "settings" in EVIC, will Alpha unlock this???
What's in the settings??? Is this supposed to be 'Stealership Only' area?
Anyone???
Jimmy07
OK, what's the difference between the two cables? One doesn't access the Radio Head Features? Or is there more?
The canbus wires from the radio can only be accessed at the security gateway module connectors, not the junction blocks that the kaodtech harness accesses. Access to the radio is the only difference between the two.
BlownGP
Houston/Baton Rouge
Oh ok. So that's what you were saying when I asked about it.
Makes sense because I tired to access the radio and it would not connect.
Is that because I have 18 and it's locked out even using the Kaodtech by pass?
trendsetter710
2015 Ram 2500 AlphaRex Nova headlights keep getting left turn signal out. I have set everything to led and cleared the codes. They work for a while then boom hyper flash and turn signal light out message. Any advice?
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
That's correct, the Kaodtech (Deereguy) bypass method leaves the radio and it's cellular connection behind the Security Gateway to prevent the possibility of someone hacking/taking control of the truck systems (accelerator, brakes, door locks, etc) via the radio as was demonstrated on the 13-17 FCA vehicles. This is why FCA installed the gateway.
It's up to you which method you prefer.
As long as you don't leave the autel, zAuto, or ECRI style Security Gateway (SGW) Bypass installed after changes are made, there's no way to remote hack the truck.
Mike G.
M² Mods.
via Tapatalk App!
SitKneelBend
St. Louis
3.6 Pentastar
I tested it out. I think MP3s sounds much clearer with it disabled. That's how I'm going to leave it.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Thanks @SitKneelBend , the new ECRI bypass will be here Friday and the Brotect arrived today.
I just have to remove that glossy aftermarket screen protector and put the Brotect on.
1500ram12
5.9L Cummins
I have the same issue with my custom alpharex g1 headlights. I haven't found a solution yet
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
SitKneelBend
St. Louis
3.6 Pentastar
Yikes not good.
One "solution" may be using a cluster from a 2013. I noticed when testing clusters that when I replaced my 2013 cluster with a 2019 and 2018 cluster I received light out messages that I normally never see. I suspect the 2013 cluster is slightly less capable then 2014+ clusters and doesn't have as many warnings programmed to display.
chrisbh17
As @1500ram12 mentioned, I have a similar issue.
Mine only occurs if I have the turn signal engaged and the auto-headlights turn on at the same time. The signals will blink a few times then throw up the error and hyperflash. Sometimes it clears up by itself, other times it does not. Most of the time it only happens with the left signal on.
Its not really that bad since it only happens under a certain condition...I can usually avoid the condition altogether.
The only reason I can think of is that when the headlights go from DRLs to full-on-headlights, they "blank" the power between the two modes, which drops power just long enough to make the truck think the signal is out. It might be a timing thing (i.e. if that blank happens while the signal is either on or off). In my case, my AlphaRex headlights are modified such that the upper and lower LEDs serve as DRLs, but the lower LED also does sequential and switchback for a signal. So maybe the truck thinks its a DRL but when the headlights come on and the DRLs go off, maybe it drops power to what it thinks is a DRL, but is actually my turn signal which then triggers the error.
I was thinking of putting either a resistor to make the truck see a load, or a smoothing capacitor to try and save some "reserve" power for when the headlights switch on.
1500ram12
5.9L Cummins
You'd be solving one issue and creating another. 13s use a different frequency for the tpms. So you'd lose that feature
1500ram12
5.9L Cummins
I believe mine only occurs when the headlights are on (99.9% of the time are on auto) and using the left signal. But doesn't happen always. Not sure if related to a certain number of uses or x amount of duration of use. But once it happens I just leave the left signal on until the hyper flash stops. Usually under 10 seconds.
chrisbh17
Mine used to reset itself pretty quickly, but some point along the way that stopped happening. I now just flick the headlights off with the signal on until the hyperflash goes away.
I thought mine worked a little better once I used more sane voltages for the LEDs (12V instead of 14V or something like that), but again that eventually became short lived.
I know the answer is probably a resistor, but and too lazy to try and find the bare minimum amount of resistance necessary to trick it. I surely dont want a huge honkin generic load resistor if its not necessary.
SitKneelBend
St. Louis
3.6 Pentastar
I've heard that but it works in my 2014 Express...one thing that's off is you can't add the settings menu to a 2013 cluster and I think Turn by Turn graphics are missing/corrupted when getting NAV prompts from a UAQ.
1500ram12
5.9L Cummins
I had a 2013 cluster in my 2015 I had and the tpms didn't work. Which was fine with me because I had aftermarket wheels without sensors
Ricks Ram
The 13 cluster TPMS should work in the 14 to 17 trucks. I have a 13 in my 14 and it works fine. The problem is when you put a 14 up cluster in a 13 truck. This is when the TPMS doesn't work properly. At least this is what I've experienced in many of the trucks I have upgraded. I have no idea why it doesn't seem to affect them the other way.
Sent from my SM-G981U1 using Tapatalk
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
I was able to stop the problem with my switch backs shutting down park side by using 300 ohm resistors. 2 watt is big enough but I used a 10w metal cased for the extra heat dissipation ability.
Sent from my SM-T500 using Tapatalk
Abnsapper
South Carolina
Hey guys. This may be a little late, so I suppose it is for future reference. I have been using VeePeak OBD II Bluetooth adapter with Alphaobd for several years now and I have not been let down yet. I bought it off of Amazon and I believe I paid a whopping $14 for it. Not a thing wrong with it. Everything from simple changes such as tow mirror signals to RF hub reset.
