mjf6175
I just called the dealer and talked to the manager. He guaranteed I had the right code. So I’m going to say my email I got back from the creator of Alfa was on point that Alfa cannot program a 2018 with all the new security crap
2018 Black Pearl Ram 1500
LED Tail Lights, Black 4 Quad Halogens with HID conversion, LED Black 3rd Break Light, Blacked Out Emblems, 8.4 UAQ conversion!
Lawsuit...as member mtnrider says, you need to reset the RFH hub.
Changing the TPMS is a 2 step process. The first step is to change the pressure settings in the BCM. The changes you make in the BCM MUST be mirrored in the RFH hub. To do that you have to re-set the RFH hub using the Alpha program. When you go to the screen in the Alpha program to do this, the program will ask you for the 4 digit code you got from the dealer. When the RFH hub resets itself it checks the BCM for changes made to it and incorporates them into the RFH settings.
