Ricks Ram
- Joined
- May 1, 2015
- Posts
- 4,411
- Reaction score
- 3,415
- Ram Year
- 2014
- Engine
- Hemi 5.7
When I set mine to the 35" Toyo with the Alpha tool there was no place to enter the tire sizes manually that I saw. I'm not plugged into my truck right now but I just opened the tool and looked again and I still don't see the option to enter it manually. My truck is a 2014 1500 so not sure if that may be the difference.Well just to confirm 2018 Ram 2500 was able to change tire size for my 37's. When going to change tire size there is a block to manually add the circumference in mm, below all the preset tire sizes.
After changing that and cycling the key, my cluster lit up like a christmas tree. I went to the ABS module, and used one the drop downs that I could connect to was not one of the Ram ones but it was the only one I could connect to. Followed the ABS initialize steps, which has you initialize ECU, then clear DTC's, then rolling logs.
Had to clear codes in the ABS module, BCM and Engine. Another key cycle and lights all cleared. And speedo was changed successfully.
This was done on the android version, with the MX bluetooth reader and a bypass for the 2018
Will work on a write up, as I had to do it a couple times to get the right circumference numbers.
