AlfaOBD
Hemi395
Cape Cod MA
Is there anyway to set the BCM using Alfa to recognize the 32 gallon tank?
alpinegreenneon
Air Force
South East Wisconsin
Good news! I was able to program two keys for my 2018 RAM with alfaOBD and the OBDLinkMX. I did use the Security Bypass cable. These are just keys, not remote fobs. My Ram is a Tradesman without RKE and there are real locks on both doors. The key blanks that I used were from eBay and are the type that can be pried apart to remove the key blade so it can be easily cut to match the original key blade. Just search eBay for Y170 key blanks and find the type that shows the key blank apart.
Start alfaOBD, Select the RAM icon. Select Radio Frequency Hub (RFH). Then select the Radio frequency HUB for the Control Unit. Touch the open hood Fiat icon. ENTER the 4 digit PIN. Select Procedure to start and scroll down to "Program Ignition FOBIKs Baseline System". You then remove your original key from the ignition node and insert the new key into the node but leave the ignition position to OFF or Lock and press Start. After a few seconds, it will say Completed.
Outbreak
Cummins 6.7
So here's a thought. With many people changing settings they shouldn't be and messing up some things in their truck (me included). Wouldn't it be nice to have the options to load all of your initial settings back onto your truck? For example, with the initial download of your "System Information", AlphaOBD should be able to save that somewhere. Then if you mess some settings up, you could simply install your truck specific settings back onto your truck, and start back at the beginning.
Lawsuit11
Westland, MI
You should send this to Alexey. The creator of Alfa you never know what you will get back
2018 Black Pearl Ram 1500
LED Tail Lights, Black Quad Halogens with LED conversion, LED Black 3rd Break Light, Blacked Out Emblems, Rims & Grill, 8.4 UAQ conversion! MTC to ATC Mod almost
Ghost_RAM
Ghost_RAM
VA
There are a few fuel tank 1&2 calibration settings but I am unaware of anyone who has used them. Proceed with caution.
chrisbh17
Would be interesting to see a BCM dump from someone who has had the 32 gallon flash (that is actually working)
I dont know if Alfa can show the current values for those settings without attempting to change them first. The "E stop datum" and "Empty" values would be very interesting to see between a 26 gallon truck and a 32 gallon (with working update).
EDIT: not sure who's config it is, but this is a '17 RAM 2500 Cummins BCM dump from the shared config folder:
Cluster Configuration:
Fuel Tank Calibration, Full: 98%
Fuel Tank Calibration, Empty: 16%
Fuel Tank Calibration, LFW: 23%
Cluster Configuration 2:
Fuel Tank 2 Calibration, Full: 91%
Fuel Tank 2 Calibration, Empty: 2%
Fuel Tank 2 Calibration, LFW: 8%
Does the truck really have 2 tanks? Not quite sure why the difference in the 2 configs but maybe its a clue. (it looks like 91/2/8 is the standard config for most trucks according to the shared data)
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Yes technically the Cummins does have two tanks. One for diesel and one for DEF fluid.
dav8388
Summerville, SC
In limbo between trucks
3.6 pentastar
mine has the 32 gal tank that is working accurately. I'm not near my truck right now won't be til Wednesday. I'll grab a screen shot when in able to.
Big Terry
Dover OH
Hello. New to this forum and need some assistance. Just purchased AlfaOBD and am trying to use it to activate the DRL's on my 2013 Ram Laramie Limited. I have done the following:
FROM "CAR CONFIGURATION CHANGE":
- Selected "DRL Configuration".
- Selected "OPTIONAL DRL" (also tried "CANADA DRL")
- Hit "START" and "NEXT" and got message saying that the change had been made.
- Selected "DRL LAMP LOCATION".
- Selected "TURN SIGNAL DRL" (also tried "FOG LIGHT DRL")
- Selected "DRL DROPOUT".
- Selected "ENABLED".
FROM "PROGRAM CUSTOMER FEATURES".
- Selected "DAYTIME RUNNING LAMPS".
If I go back to the "Body Module" and do a "System Status" it shows the following:
- DRL Configuration: Optional DRL
- DRL Lamp Location: Turn Signal DRL
- DRL Dropout Enable: Set
However, I still don't seem to have DRL's enabled. At first I thought that maybe the DRL's aren't on if the vehicle is running but in PARK, so I activated the parking brake, left the truck in DRIVE, and got out and looked, but still no DRL's.
Any thoughts/suggestions would be appreciated. Thanks!
Vehicle cannot be in park, or have the parking brake engaged, for DRLs to come on. I knew this and still struggled because I engage my parking brake every time I pull in the driveway, and forgot about it as I was making my settings changes.
Big Terry
Dover OH
Did you go into your settings menue on your radio under (lights) and see if the code is there?
I can't get the setting to display in my lights menu. Think I'm missing a setting somewhere, although my DRLs are indeed functional.
Ricks Ram
Were you able to find this setting (Daytime Running Lights CSM) in your car configuration list?e3317dbed239a5dd7ff9c3072c146e83.jpg
Big Terry
Dover OH
You know, I saw a ****load of CSM settings in there, and I'll bet I scrolled right past it while I was hell bent trying to find the other ones.
BRB, going out to check.
Ricks Ram
Remember you need to actually be connected to the truck for the CSM settings to show up on the tool.
Big Terry
Dover OH
This is what I've got, and DRLs are indeed working. d497749ac828afc60a2d909ab162e1b9.jpgd6a6c88ca9b7ca38f7cb95c0415c7324.jpg
Big Terry
Dover OH
Just found this one as well. Maybe this one was the missing link. 14bf64c7fc0f8be542926d10d2d1a6e7.jpg
Ricks Ram
Yes that may be your problem. These are the codes necessary for the DRL's. Make sure you give it some time to show up on your screen. 34d05f692a78b8cce1351bdbc79e780b.jpg
Reactions: JB1
Ricks Ram
Also I see you have a UAQ radio. It takes quite a bit of time for options to show up on the screen with these radios when they read your BCM so definitely give it a day or so.
Big Terry
Dover OH
Ahhh, OK. Did not know that.
Side note: my radio is going to be replaced in a few weeks for a warranty claim (android auto doesn't work anymore, and two hours in service this morning was enough for them to decide **** it, swap it.) The settings made in the BCM are resident in the BCM alone, correct? So a radio swap will just auto-populate with the info already present, I assume?
Ricks Ram
Yes As long as the dealer does not flash your truck for any reason which they should not all of the settings are in your bcm and eventually the new radio will pick them up.
noraa73
