Ralph Bucci
Does anyone know how to get the mirror turn signal lights to become running lights when my headlights are turned on? I can’t seem to find any setting to change that feature.
We have tried all the settings with the alfa tool and have been unsuccessful so far.Does anyone know how to get the mirror turn signal lights to become running lights when my headlights are turned on? I can’t seem to find any setting to change that feature.
Anyone have this problem or know of anyone I’ve tried enable hid and also ledNot sure why but I’m getting this when one of my low beam lights don’t turn on they are hids
I have not tried it but I think that you can change the TPMS from the base system which is the one you have to the premium system which just shows the value of the sensors with no alarms like the 3500 have. I have thought about trying it but I like the idea that it will at least beep at me if the tires get to low. I see why you would not want that.I've read through quite a few of the pages. Last night I calibrated my speedometer. Fortunately with success.
Is there a setting to disable tpms, I see where the threshold is. I need 3 sensors for the truck and just don't care about the feature so I don't feel like buying new ones.
Also can I disable the rear bumper parking sensors?
No. We enabled it but there was no change. We still could not add addresses manually while the vehicle was in motion. We tested it in a 2014 and a 2015.
It is under VehConfig 3 Base TPM system present or Premium TPM system present.I'm 99% sure you van change it to the base line system(forget what it's called in alphaobd) a bunch of people on cumminsforum have changed it
Thanks, although I can't find VehConfig 3. I don't see it under tire control or body computer.It is under VehConfig 3 Base TPM system present or Premium TPM system present.
Body computer - Select your control unit (truck year) - Active diagnostics (car with hood up) - select procedure to start choose at the bottom "car configuration change" - Select option - scroll to VehConfig 3 Find the base and premium selections. They are close to VehConfig 4. These show up even if not connected to truck.i'm not. i'm sitting at work looking at the app.
I had that issue and it had nothing to do with the truck or alfa, it was a bad igniter on the HID, for HID you should only enable Hight Intesity Discharge and leave the rest of the settings alone.Anyone have this problem or know of anyone I’ve tried enable hid and also led
A little late but I got the cheapest one on ebay that was elm 327 and it works well.Been reading a lot about alphaobd today cause I need to update my tire size.
I see that everybody uses the obdlink mx. Are there any others our there that work. I'm guessing this one is the best. Just curious.
I have seen this happen in the past. Sometimes it takes several key cycles for the radio to catch up with the truck. This is especially common on the UAS and UAQ equipped trucks. Your radio is most likely fine and just needed to have time to read the BCM changes. In any case congratulations that it's all working correctly nowUpdate on my Issue: Had all of my screen controls along with ABS, Traction Control,and Brake light on Position after installing LED Tail lights and Projector Headlights for HID's. Was able to set everything back to stock and went to the Dealer today. Got it all sorted and they could not find out what the issue was. My Radio did not come back to Original settings for operation and they told me they are ordering a New Radio. Later today I started my truck and moved it into the Garage and went to see if I could change a couple settings on the Screen. Lo and Behold All of my Temp and Audio Controls came Back to Factory settings. I am going to have them install the New Radio when it arrives anyway. Thanks to everyone who had input and suggestions to help.
