Ramsportrocks
Yes each one is only one step.
excellent, thank you
Does anyone have the link to the 09-2012 AlfaOBD thread? I have searched for 10 minutes through this website and google and haven't found it. I want to see if I can reprogram some things for a coworker.
Thanks
What would be those items you activated?Just an FYI - anyone that is looking for tilt in reverse capable mirrors, mirrors from a Harvest Edition seem to work!
The Harvest Edition seems to be a Big Horn on steroids, but it comes with the chrome capped (presumably Laramie/Limited type) mirrors. Auto tilt in reverse is NOT an option on the Harvest edition, but I just installed a set on my Big Horn, activated the right features in Alfa and voila! I have auto tilt in reverse now.
Normally I wouldn't have pushed so much for this relatively innocuous option, but our trucks are so high off the ground and my front windows so tinted that I could really use the tilt down feature when I park.
Memory mirror passengerWhat would be those items you activated?
Sent from my Nokia 7.1 using Tapatalk
Thank you. I’ve been slowly changing everything to led. All that’s left is my brakes/turn signals and my drive/turn signal in the front. Then high and low beam but I’ve got headlight revolutions v4 fogs that I’m liking so far and no radio interference so I think I’ll order those for high and low"If I install profile peak switchback led 3157 in my turn signals front and red 3157/3156 for brake/turns in the rear will I get hyper flash if I switch the settings to led?
https://www.theretrofitsource.com/l...7-profile-peak-led-bulbs.html?preselect=53524
Edit: without resistors. Don’t want to modify the wiring if I don’t have to "
It shouldn't because if you go into Alfa and set it.
Yep my 18 harvest addition has those Mirrors and once the codes where in i got tilt in reverse to work as well .Just an FYI - anyone that is looking for tilt in reverse capable mirrors, mirrors from a Harvest Edition seem to work!
Congrats man that's what this forum is all about! Fantastic work there! Keep it up and help someone new out whenever you can!Loving this app. Just shed about 2 pounds of resistors and harness that still gave me bulb out warnings... now no bulb out messages and no harness/resistors.
So far set fogs with highs on
Set fogs to Led
Set headlights to hids
Set TPS to 45 pounds no more 80 pounds or light on
Set tires to 295/65 or 2800 mm
Set window down express mod.
Activated DRL in the turn signals with dropout
Anything else people have found useful? Tried reading through the post but just crazy how much infos in here..
Sent from my ONEPLUS A6013 using Tapatalk
Are OEM projector headlights and led tails now plug and play or are the OEM harnesses still different? Thanks
That is in car configuration change all the way towards the bottom.
Daytime Running Lights CSM
Did they update the drop down menu's or something because I can't seem to locate this option at all and wanted to add it to the 8.4 radio under settings.
I am under the body computer > My2013-17 Powernet > Car Configuration changes > and I cant seem to locate the option to display it on the radio. I did see all the other options and enabled them and they are working but wanted to put on the radio as well since I am going to do it for my brother and a friend so they have the ability to shut them off if they want to.
Looking at that screenshot, it will say exactly this- “CustSetMenu 1- Daytime Running Lights CSM”.Yea even scrolling through the massive list I still dont see them... not sure if Im blind but no CSM or any Daytime Running light mention that I can find..
