AlfaOBD
gapi
Georgia
HEMI 5.7
Ok, finally went back in on the charger for wire pics. The white plug has 6 wires. And the door modules are the same p/n as cars shipped with them
I installed memory, tilt in reverse mirrors but cannot get them to work. I found "Drivers-Door Memory Mirrors Present". Same for Passenger.
I don't have CSM settings in the Charger listings. Can it be called something else? Maybe I missed something to get it to come up in settings list?
Patrity
3.0 Ecodiesel
I already have a longhorn package so I have every option enabled I'm pretty sure, but the rebels have that offroad-type app on the radio. Is it possible to unlock that? 2016 ram 1500 laramie longhorn.
diboblo
California
Try selecting another MY Powernet.
Iflyabeech
Mission, TX
2015 Ram 1500 4x4 Outdoorsman Crewcab
Ecodiesel 3.0
For anyone attempting to add a key to their vehicle using the PC based version... don't.
I had no original key, and I refused to spend $300 at the local stealership + a tow for a replacement... my local thief (locksmith) quoted me $200 just to program my $18 amazon key. So I took this challenge upon myself. I spent HOURS reading this thread, and followed the instructions I found to a "T". After asking my local stealership for the pin, they told me I couldn't have it. To save myself any more aggravation I took this alternate route:
I used the OBD LINK MX ($69) + CHRYSLER PIN PULLER APP ($15) ((available only on the google play store))...
After 2 hours of getting nowhere fast, I was met with an error message: "ACCESS DENIED INCORRECT PIN", so I decided to take my troubleshooting even further. I rebooted, retried, and even updated the ALFAOBD software to the most current version available on PC. And yet... the same error message appeared.
Lastly, I decided to purchase another copy of the ALFAOBD APP from the google play store ($50).
Took 3 seconds, and Immediate success.
Fortunately, this disaster/success story only cost me a total of $28.
Moral to the story: DONT BOTHER PROGRAMMING YOUR KEY WITH THE PC BASED VERSION OF ALFAOBD, IT WILL NOT WORK. oh... and don't let any service tech, parts counter employee, locksmith or anyone take your money.
I got an Amazon key that I was unable to program via the PC version of AlfaODB. version 2.07.00. I gave me the "Failed. Conditions not correct to request sequence error"
I updated alfaodb to 2.08.00 and tried again and it flashed it immediately.
Amazon key works great now! Im not sure when 2.08 came out, but I can confirm it does allow key fob programming
East0352
Hernando, MS
6.7L Cummins
Check your dynamic tire circumference. I checked mine and it was 2470 when it should have been 2640. I checked a friends and his was smaller than his tire size was also. Looks like FCA is jipping is out of about 10% of our mileage making our MPG seem better and warranty run out faster.
kad
Hudson Valley, NY
5.7L HEMI
My 2014 with factory 20" wheels, running factory sized 275/60R20 tires (aka 33" tires) is already set at 2640. What wheels/tires was your 2016 equipped with from the factory?
-K
crzyamerican
Air Force
3.0 Ecodiesel
For a 2018 Ram 1500, do you need the Bypass harness to turn on the Trailer brake?
Or do you need the bypass harness for "Any" changes
Lawsuit11
Westland, MI
You need it for ANY changes in the bcm/RF Hub.
Scar1331
Dallas
Ok purchased the Security bypass module, do I still need the bluetooth OBDII ??
All I really want to change is the TPMS if anyoenis local in dallas
WVRam68
WV
Yes, that’s how Alfaobd talks to the truck.
jwilkinson79
West Islip, New York 11795
Any help is appreciated, I upgraded to power fold mirrors, changed the modules & switch. I can't get these things to fold also my power door locks stopped working....
Ricks Ram
Are you sure you installed the correct door modules? Do you have the part#s? Also are you sure you connected all the plugs on both modules? Did you change any other codes except the power fold?
stimpy433
IOWA
@Ricks Ram, how many wires are in the white plug on a side mirror that has tilt in reverse???
noraa73
