With all the knowledge here I'm hoping someone can help. I have a 2016 RAM 1500 Express with 5.7L Hemi. The OEM radio was the 5.0 Uconnect touchscreen. I have replaced it with one of the Tesla style radios from Phoenix. I have used AlphaOBD to change all kinds of things, DRL, Fog Light Dropout, etc. I upgraded to the 7" evic cluster and added the OEM trailer brake control module. With the addition of the Tesla radio I lost the ability to have access to the trailer tow settings that were available in the 5.0 Uconnect radio. Some 7" evic screens have the "vehicle settings" menu available and these are the ones that came with the OEM RA1 3.0" radio that did not have access to the settings menu in the radio. Hence the availablity of the menu in the evic. Can this settings menu be added/activated in the evic using AlphaOBD? Or by any other means? Or do I have to look for a 7" evic cluster that came from a vehicle that had the RA1 radio originally? Will that even work? Thanks for any hep.
I did that by accident on my RA2 / basic cluster with alphaobd
I believe it was IPC feature config option
ECU Configuration 4:
ERS Available: Set
Rear Wheel Dually: Not set
Max Gear: 8
Virtual Speedometer Units: Not available
Speedometer Range Max Scale: Not available
IPC Feature Configuration: Not available
PTO Present: Not set
Ambient Dimmer: Not set
Heated Seat Present: Not set
Split Shaft Present: Not set
Manual Headlamp Leveling: Not set
Gear Shift Indicator: Not set
Service Interval: 20000 km and 730 days
Temparature Celsius for UK: Disabled
Type of Gallons: U.K. Gallons
Wireless Configuration:
