AlfaOBD
puschel_1
Germany, Bavaria
Hi @ all,
is there a way to test the AGS Active Grill Shutters in my 2014 RAM 1500?
I think they are defect an d want to run a test with AlfaOBD is possible.
Thanks in advance!
Florian
Hum_Dynasty
California
6.7l
Hello. I am new to the thread. I have a 2015 ram 2500 6.7L Tradesman. Last night was my first night using alphaOdb. I must say I’m impressed. I was able to disable my seat belt chime, fix my bulb out indicators warning (which fixed my issue of my aftermarket Morimoto xb led headlights turning off while I was driving), I enabled drl with my led parking lights and turned on global down to get the windows rolling down with the remote. I also tried to activate the factory alarm. But it only turned on the red light in my 3” evic. Anyone know if I missed something. I used big daddy’s house for the steps.
Lin & misc - vta system present
Select vta
And it didn’t work for me.
Thanks for any help out there [emoji1689]
Shugarrckbx
Welcome to the forum! I just got done doing that on my tradesman 2014, followed the same video, and everything works, try disabling it, wait five mins and enable it again. Also if you let the truck sleep for a little maybe that will do it, sometimes it takes a little for these things to set..;)
Hum_Dynasty
California
6.7l
After driving it for about 40 miles. I tried it again and it works. [emoji2371] [emoji1319]
brianw0048
EcoDiesel
I just installed hikari led fog lights, 9006 size and they won’t come on at all.
2016 big horn. Vertical, halogen fogs came stock.
I have alpha obd and changed the fog light dropout to “NO” and selected “YES” to LED fog lights present. I have also selected “YES” to enable HID.
Is there another change I need to make?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Try unplugging the bulb and flipping the plug around.
Kenepo17ram
Brooksville, FL
I have same led and I didn't make any changes for it
Sent from my HD1925 using Tapatalk
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That did it but man have I got some tuning to do before running these things...
Try running them at the 3 and 9 o'clock position
2018 Ram 2500 6.4L Hemi Tradesman
1500ram12 is right. Luckily the Hikaris are clockable and the foglights easily accessible. Just grab the fan housing on the back of the bulb and spin it until the power cord wire is at the 6 o'clock position (which should face the LEDs to 3 and 9 o'clock)...
brianw0048
EcoDiesel
Thanks, I’ll give it a shot. I’m waiting on an adjustment screw; I found one missing the other day and my fog lights were lighting up the tree tops.
RLT1
FL
Can someone help me figure out the backup camera so I can view anytime. I made all the changes listed but do not know where to find it on the uconnect?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
A long toggle anchor bolt will do the trick. The factory adjustment nuts seem to shake off...
1500ram12
5.9L Cummins
On the 5.0 if you hit the + more button it appears there. I could have swore that when I first had my truck I was able to use it but now does nothing. I haven't tried doing anything with alfaobd yet
RLT1
FL
I have the 8.4
Any ideas on this one? I don’t see it.
RLT1
FL
I did but it didn’t come up. I’ll check again tomorrow to make sure. thanks
frenzy_6900
