AlfaOBD
Worryabout2
Canada
Eco diesel 3.0
hi, I have 2016 Ram 1500 eco diesel with orginal factory installed remote start, now it coming out a Check Engine light on. the error said the PFD need repair, but the shop want to change me $1500 to do it, does anyone know how to bypass this error messenge using Alfaobd software , so I can still remote start truck under cold weather. thanks.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Go into Playstore and click on upper right icon in the screen.
Then click manage apps & devices.
Then click on updates available.
Finally, look for AlfaOBD app to see if an update is available.
Thanks for the info! It says it's up to date, version 2.3.4.0
davuzzi
florida
3.0 Eco diesel
Hey guys new to this but I don't know were else to go. I built a welding bed for my RAM 3500 and it was squatting a little low so I went in to change the ride heights and now I'm locked out. Says the air suspension module is in plant mode. I've tried multiple times to clear the DTCs and they will not clear. And I am not able to change any settings. Any help in this department would be greatly appreciated.
Found this forum after being foolish enough to mess with my air suspension yesterday, on my 2014 ram limited with air suspension. Spent hours trying everything. truck was squatting really low. I went into the setting on the vehicle through the screen on the dashboard, put the suspension into alignment mode and it took the new suspension heights after literally trying everything and getting multiple codes. I had the plant mode issue, c156e00 code as well. found the heights with a simple google search. i used the check sensors option on my xtool d7 to get it out of plant mode.
thanx to everyone who posted questions and answers to these issues.
Brew99
Victoria, Canada
I've got a FOB from my 2016 RAM that isn't recognized by the truck for ignition (lock/unlock works fine). It was intermittent over the last month, and finally died. Changed battery, but still "duff". I've programmed a new FOB via AlfaOBD, so that's great. Thought I'd try and re-program the "duff" one, but it looks like it isn't being recognized when starting the "program FOBiK baselink" routine.
Now, should it be possible to re-program a FOB that was previously used, or is the thing just "toast"?
USPatriot1776
Kentucky
Not sure if this has been said but if you want to emulate what a pedal commander does change two settings in AlfaOBD:
ECUConfig14 /Acceleration Threshold: Filter Off
ECUConfig14 /Acceleration Factor: Filter Off
This made a huge difference in my throttle response. I've seen a few people debating whether it actually does anything but I can confirm that if you set it to those settings you will feel a difference in throttle.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Where do I find this in AlfaOBD to check if it is on or off?
Thanks in advance
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Found these on my 2017 but there is only ECUonfig4 on my 2013.
Jimmy07
Placebo effect. Those settings can’t possibly change the sensitivity of the throttle pedal (controlled by PCM, not BCM).
ECUConfig 14 deals strictly with the BCM configuration for the occupant restraint control module (it’s gyro and accelerometer, etc).
USPatriot1776
Kentucky
I can 100% tell you it is not a placebo there was a noticeable change in my throttle response. There used to be a slow ramp regardless of pedal position. Now it's much more responsive. There is also a setting in there that deals with brake smoothing and steering smoothing under the same Configuration. That effects the brake and steering wheel as well.
NETim
Nebraska
5.7L
Just out of curiosity, why would the voltage for the DRL's be an individual adjustment for left/right DRL's? I wound mine up from the default 7.4v to 9.4v on each side. 7.4v was pretty dim, as in, what's the point? Might crank it up more if needed.
Also, obdlink EX interface, the USB version, works well with my newest Chromebook, which doesn't like playing the BT game at all. It would connect, then disconnect immediately, regardless of what I attempted. I think it has something to do with the "low energy" BT standard.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Through the module they are seperate circuits. Many vehicles (European) have always been seperate circuits since the 80s. If there is an issue on say the left circuit, the right-side will still be powered instead of losing them both. Because of that there are left and right adjustments.
USPatriot1776
Kentucky
Could they be called something else on the 2013 truck? Even searching by name, nothing comes up.
Potentially, but they just may not be there in that truck. I would try things like looking up factor or smoothing. Brake smoothing is in the same category so if you find that you may find acceleration
EDIT: Just looked through the 2013 BCM module and it doesn't appear functionality is there for that.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
I really appreciate the help.
Thanks for the reply too!
Tony15068
PA
3.6L V6 24V
Have read some conflicting information. Need to enable power folding mirrors on a 2023 1500 classic warlock. Going with an OBDLink MX+ and would prefer to use AlfaOBD and although their support page seems to indicate Alfa will work with a Windows 10 PC, I just wanted to make sure before I commit.
Anyone here using Alfa and MX+ with a Windows 10 laptop?
Thanks.
alphaprojects
