AlfaOBD
RamDiver
Marlborough, Ontario Canada
2021 DS
My truck has 29337 miles on it and I put it to 24000. It went to 14900. I been trying to correct it it but can only get it close.
Is there a possibility that you're setting the mileage in a location that is looking for a value in kilometers?
24,000 km * .625 = 15,000 miles
In the above example;
29,337 miles * 1.6 = 46,939.2 km
I checked active codes and u1412 implausible vehicles speed signal keeps popping up.
This sounds like the tire circumference size is set incorrectly. This condition will also mess up the speedometer and the odometer readings.
Is the speedometer working properly?
I set custom tire sizes for winter and summer wheels and used an old standalone GPS to fine tune the setting.
I'll post the AlfaOBD location for tire size a bit later when I start my PC, using a phone ATM.
Sam d
Ny
It was definitely the tire size . I put it back to stock size and it fixed everything
Jimmy07
Just finished performing the Update TPMS Threshold on a 2024 PW. It appears to have taken, but my TPMS light is still on. Display shows the corrected PSI. Anyone seen this before?View attachment 547796
Change the pressure thresholds back to the original numbers, inflate the tires up to those thresholds, THEN change your thresholds to the lower number and deflate down to what you want.
Aztechead
@Jimmy07 thank you! Performed those steps this morning and it fixed right up!
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Jeez, I'd never think of that. Good info!
broncoduecer
MT
Had my windshield replaced and the auto wipers aren’t as sensitive as they used to be by quite a lot (2017 ram 1500 Laramie). I saw a few posts on people adding the rain sensor and enabling it via AlfaOBD, and some mentioned calibration settings.
Is there a way to calibrate the sensor with AlfaOBD?
Has anyone tried that out?
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Under BCM AND Configuration.
musinxa
Belgique
problème ecu, défaut mod...copie bcm...
merci de confirmer ou non le problème
Dodge Ram 1500 DS 4x4 cabine multiplace Laramie 2009 5,7 litres
  • dodge 2009.txt
Hemi Freak
2024 Ram Power Wagon: After adjusting my tire size with ALFA OBD a couple of weeks ago, today my front park sensor is turning off on its own after driving for a few minutes and the sensor switch shows off and wont turn on. The message is shows when turning off says "Front Park Sense Unavailable." When I click the switch to turn it back on, a message shows up on my dash saying Wiper Sensor. Not sure if this is related to the tire size change using ALFA. The dealer did have to take off my bumper about 4 weeks ago to replace a DTR light, but everything was fine after that. The dealer also had to replace my battery three weeks ago and after that is when I adjusted the tire size with ALFA.
Today when I shut off the truck and turn it back on and drive, the sensor seems to be active for about 5-10 minutes then it shuts off again. Also, my sensors are clean. Alfa shows no codes for BCM or ABS.
This evening the "Front Park Sense Unavailable" message came on briefly then it started working again.
Any ideas for fixing this?
RamDiver
2021 DS
Ce site utilise la langue anglaise.
Je vous suggère d'utiliser google.com/translate pour publier des messages ici et vous obtiendrez peut-être une meilleure réponse.
De plus, ne vous attendez pas à ce que quelqu'un ouvre des pièces jointes inconnues d'un nouvel utilisateur.
Ce fil de discussion concerne les aventures liées à AlfaOBD et non les pannes générales.
Vous aurez besoin d'informations beaucoup plus détaillées pour obtenir de l'aide.
Essayez d'ajouter ce que vous essayiez d'accomplir lorsque cette erreur s'est produite, etc.
Bienvenue sur le Ram Forum.
rubes7202
PLEASANTON, CA
These are what your settings should be that have to do with DRLs:
DRL configuration >optional
DRL lamp location > dedicated
DRL dropout enabled > yes
CBC I/O right dedicated DRL lamp output present> yes
CBC I/O left dedicated DRL lamp output present > yes
LED dedicated DRL present> yes
ECUConfig 3 DRL customer setting enable> yes
CustSetMenu 1 daytime running lights CSM> yes
These settings are for 2015 RAM with Factory Projector Headlights, right?
diymirage
Banned
Question
On my wife's journey, the fog lights cut out when you turn the brights on, does anyone know what setting that is in alphaOBD ?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Custom.Set.Menu 1: Daytime Running Lamps: Enabled
ECUQualifications:Control‐Dedicated DRL: No
ECUConfig 3: DRL Customer Setting Option Present: ' Yes '
CBCFeatures: DRL Configuration: Optional DRL
CBCFeatures: DRL Lamp Location: ' TURN SIGNAL DRL '
CBCFeatures: Daytime running lights CSM Present: ' YES '
CBCFeatures: DRL Dropout Enabled: Yes
CBCFeatures: LED Dedicated DRL Present: No
These are what I did on my '16 Sport with OEM projectors. Believe the '15 and '16 are the same.
What you show above is "dedicated" DRL. Thats OK for Canada, but they weren't mandatory dedicated DRL's in lower 48.
giesloga
wisconsin
2014 ram 2500 laramie 4x4 cclb g56 nv271
6.7 cummins
Does anybody know if I can trick 2014 ram 2500 into thinking it’s 2wd. I put in a manual t case and my transfer case control module went bad and I can’t get the abs to flash. The abs light isn’t on but the one that looks like traction control light is on. It’s right above where if you turn traction control off light is but it doesn’t say off
04fxdwgi
2016 1500 Sport
Don't know if it will effect it, but on my '16 there are:
VehConig7: Transmission Equipped: Automatic transmission
VehConig7: Automatic transmission type: ZF 8‐Speed
PT/Chassis Net: TCM Transmission Control: Enabled
Since you put in a manual, perhaps turn off the TCM control and see what happens. If it works, then modify the other things.
Reticle918
